Help- installed HV Melling oil pump now shortage of power. - JeepForum.com
post #1 of 7 Old 10-17-2013, 02:31 PM Thread Starter
ChaseKanter
Hi guys, I installed a Melling High Volume oil pump last weekend and it was finally warm enough today to take out the jeep. Now it feels like it has less power and starts to backfire/die when i give it throttle in 3rd.
Is the HV pump really putting that much stress on my engine?
I also switched to Rotella 15w40 deisel oil. Could the thickeness of the oil be causing stress on the pump and stressing the engine?
Here are my Jeep details.
Model/year: 1978 CJ5
Transmission: t150
Engine: 258
Oil: rotella 15w40 deisel
Oil filter: wix
Original carb (has always worked great)
It is not overheating and the oil pressure is good (15 at hot idle and 30-50 driving)
The only thing that has changed is the oil, filter and the pump. Should i switch back to a thinner oil? Any suggestions would be appreciated.
Here she is....
ChaseKanter is offline
post #2 of 7 Old 10-17-2013, 02:38 PM Thread Starter
ChaseKanter
Forgot to mention, the PO installed the "Team Rush" upgrade. So it does not have the original distributor. Not sure if that matters or not.
post #3 of 7 Old 10-17-2013, 03:16 PM
gmakra
Look for something you might have knocked off or didnt re install properly. Such as a vacuum hose or wire.
A oil pump should not cause those symptoms unless you have a really badly stretched timing chain.
gmakra is offline
post #4 of 7 Old 10-17-2013, 05:40 PM
lucdog
lucdog's Avatar
1980 CJ5
The TeamRush uses the orignal distributor, the only thing that gets changed is the wires, rotor, cap, and the cap adapter. ( the cap adapter is the part between where the wires plug into, and the distributor).
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 7 Old 10-17-2013, 05:51 PM
petey156
True. Unless, he had the presto lite ignition...
petey156 is offline
post #6 of 7 Old 10-17-2013, 06:01 PM
hp_lovecraft
1981 CJ5
Those are symptoms of either a bad vac leak, or bad timing. If you had an ignition system change, I'd check the timing first. Then make sure the vac advance is hooked up. Then start checking that all the hoses are attached, etc.
hp_lovecraft is offline
post #7 of 7 Old 10-17-2013, 06:45 PM Thread Starter
ChaseKanter
Sorry for wasting your time guys. It just happened that the corroded rubber fuel line finally gave way at the same time i replaced the oil pump... I replaced the hose and it is back to normal. Thanks for the help though. This forum is awesome..
