Help - I'm stumped - ignition issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Help - I'm stumped - ignition issues
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-31-2013, 11:45 AM   #1
82Renegade
1982 CJ7
Appreciate any help on this- I'm pulling my hair out. CJ has been running strong for years since any changes were last made to the ignition or TBI systems. The other day it randomly wouldn't start, and in troubleshooting seems I'm not getting spark to the cylinders. I AM getting spark from the coil into the distributor cap. I've tried changing the cap and rotor, but no dice. I've tested the pickup coil and its right on at 650ohm. What else could it be?
82CJ7, Howell TBI, Ford e-coil, MSD 6A ignition
Thanks!
82Renegade is offline   Reply With Quote Quick reply to this message
Unread 08-31-2013, 11:48 AM   #2
82Renegade
1982 CJ7
Any also, let me note that the fuel injectors are firing, so I don't think its an ECM issue.
Unread 08-31-2013, 02:42 PM   #3
LumpyGrits
Not much on FI.
This is SWAG on my part. Have you tested the CPS and fuel psi?
Ever change the fuel filter?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 08-31-2013, 06:45 PM   #4
petey156
1977 CJ5
So you have fuel and spark, But it still does not. Fire?
Have you checked for spark at the plugs?
Are the plugs. Damp with fuel or fouled?
petey156 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 01:20 AM   #5
W7NB
Check your fuel pump. Seems like the most common problem on TBI converted rigs.
°lllll° Am I broke yet??
1985 CJ7 With HO 4.0 Conversion
2013 JK
W7NB is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 01:31 AM   #6
titomars
1981 CJ7
What is SWAG?
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 08:48 AM   #7
WindKnot
1977 CJ7
Sophisticated Wild @ssed Guess. It's very scientific. (And usually right)
I'd rather be lost on the trails than found at home!
[b]Phoenix Rising- A Flame Off Restoration?[/b] [url]http://www.jeepforum.com/forum/f8/phoenix-rising-flame-off-restoration-1807257/[/url]
WindKnot is offline   Reply With Quote Quick reply to this message
Unread 09-01-2013, 10:19 AM   #8
LumpyGrits
Originally Posted by titomars View Post
What is SWAG?
It's 'Jeep' speak,,,,,,,,
LG
Unread 09-01-2013, 12:15 PM   #9
gmakra
Test your MSD http://www.msdignition.com/page.aspx?id=3206
gmakra is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 04:30 PM   #10
82Renegade
1982 CJ7
MSD tests ok. I also get spark out of the coil into the distributor. Just because I can't figure out what else it could be, I just replaced the distributor, cap/rotor, plugs and wires. Still no go. Plenty of gas in the carb, just no spark. What else could it be? Pulling my hair out.
Unread 09-06-2013, 04:35 PM   #11
LumpyGrits
Did you test the module in the dizzy?
LG
Unread 09-06-2013, 04:48 PM   #12
jeepwhore
Spark is leaving the coil but I didn't see where you checked to make sure the plugs are actually sparking. If they aren't I'm thinking pooched distributor drive gear or cam gear maybe.
Disconnect the coil from the dizzy, take the cap off and turn it over to make sure the rotor is turning.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 09-06-2013, 04:55 PM   #13
LumpyGrits
Hmmmmmmm, OP replaced the whole dizzy........Maybe it wasn't 'indexed' correctly on the install and is waaaaaaaaay out of time.
Easy enough to do........
LG
Unread 09-06-2013, 05:55 PM   #14
jeepwhore
LG
That was my next thought. If the rotor is turning and the plugs are sparking it could be timing related (chain jumped/broken etc.)
I don't know TBI's but what effect would it have if the centrifugal advance that is normally disabled for these swaps suddenly started working again?.....assuming the OP used the stock dizzy and locked down the advance.
:-D
Unread 09-10-2013, 08:59 AM   #15
82Renegade
1982 CJ7
I am confident I have the new dizzy aligned properly. I'm completely out of ideas on what to do.
In summary: Jeep was running great, with no changes being made just stopped firing up. Testing yielded that it was a spark issue.
Have replaced, coil, distributor, cap, rotor, plugs & wires
Testing confirms getting spark out of coil into disty
No spark at plugs
Distributor has a good ground
What am I missing? It has to be something minor- what wire could be loose or poorly grounded?
