Help identifying part on carburetor - JeepForum.com
post #1 of 13 Old 07-14-2014, 08:07 AM Thread Starter
txhunter13
1978 CJ5
I'm fixing up a '78 CJ5 and for the life of me I can't find the name or the part online to replace. If you lift the hood and look at the carb it will be in the back left corner of the carb. It's almost like a fuel line, it comes off one spot in the carb and bolts into the engine block and the line coils back and connects to another part of the carb. I can posts pictures if I need to, I'm sure someone knows what I'm talking about, thanks!
txhunter13 is offline
post #2 of 13 Old 07-14-2014, 08:12 AM
Mike Romain
Hot air choke tubing from the sounds of it.
Mike
Mike Romain is offline
post #3 of 13 Old 07-14-2014, 08:38 AM Thread Starter
txhunter13
1978 CJ5
Would the engine run with this broken? When I was removing the carb, I took it out and saw that the tubing was pretty much charred black since part of the tube going into the engine block had been broken off.
post #4 of 13 Old 07-14-2014, 08:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes it would but it would take longer opening the choke properly sand you would be wasting gas.
John Strenk is online now
post #5 of 13 Old 07-14-2014, 09:09 AM Thread Starter
txhunter13
1978 CJ5
Any idea where I can find this part to order online?
post #6 of 13 Old 07-14-2014, 01:50 PM
LibertyJeeper
Its just a vacuum line. Bring it to the parts store and they will cut you a new one the same length.
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #7 of 13 Old 07-14-2014, 03:46 PM
Jeffrok
1978 CJ5
Cull that piece of junk for a manual choke. You can find them at the auto supply house.
Jeffrok is offline
post #8 of 13 Old 07-14-2014, 04:20 PM
hp_lovecraft
1981 CJ5
The same auto supply will carry hot air choke repair kits. I've seen them on the shelf at most NAPAs, and OReillys. Its Dorman part# 76850.
I only mention it because I went the same route. 5 years ago, I had a rotted out hot air choke that didnt work. The problem is that they default to CLOSED CHOKE when the tube is broken, which fouls out the engine....
So I installed the manual kit. Easy enough to install, works when used properly. But the problem was I was always forgetting to turn it off.. or turn it on.
I struggled through that for a year, then realized you could get the hot-air choke kit for $10 or so. It works beautifully. I never worry about it. Jeep starts right up, even sub-zero. Choke works as designed.
hp_lovecraft is offline
post #9 of 13 Old 07-15-2014, 08:40 AM Thread Starter
txhunter13
1978 CJ5
Thanks guys! Could that be the reason my jeep wasn't starting in the first place? Even in warm/hot weather?
post #10 of 13 Old 07-15-2014, 09:20 AM
John Strenk
1976 CJ5
Well depends, was the choke closed when you tried to start the jeep ?
post #11 of 13 Old 07-15-2014, 10:21 AM
hp_lovecraft
1981 CJ5
If its stuck closed, it would foul out while driving, then be very hard to start sometimes. You can look at your plugs. Are they pitch black and sooty? Likewise, if its stuck open, you might need to pump the gas 20 times before it starts up. The chokes can be a pain in the pain, and responsible for all sorts of gremlins... but once you get them working well, its almost like a modern car.. lol. "almost"
post #12 of 13 Old 07-15-2014, 12:28 PM Thread Starter
txhunter13
1978 CJ5
I believe it was stuck wide open but the jeep wouldn't even start. It would crank over and only keep going for a short time with some starter fluid in the carb. Then at the end when it would die out it seems there was a loud whining type noise coming from the bottom of the engine.
post #13 of 13 Old 07-15-2014, 12:32 PM
John Strenk
1976 CJ5
Someone could of set it to stay open all the time and pump the gas pedal a gazillion times to make it start.
It's probably whining because you haven't spent enough money on her yet or the starter is complaining because your cranking on it to long...
1978 , carb , cj5
