Help Identify Mystery Wires - JeepForum.com
post #1 of 4 Old 07-02-2013, 10:50 AM Thread Starter
OrangeCrush79
1979 CJ5
Does anyone recognize any of the three wires shown in photo and or what their intended destination should be? 79 CJ-5, 258, no aftermarket accessories, all other wires are plugged in as needed in dash. All other wires behind dash appear to be connected with no additional plugs / blocks needing attachment. The wires appear to be coming from the main loom near the fuse block / engine bay. Also, should all the slots in the stock fuse panel have a fuse installed regardless of there being something plugged into that circuit? Any guidance much appreciated.
OrangeCrush79 is offline
post #2 of 4 Old 07-02-2013, 10:57 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Neutral Lockout for Quadratec Blue wires, Note Jumper for manual tranny. Plugs into PRNDL switch
Quadratech Kickdown {Yellow} goes to switch on accelerator pedal
Reverse Switch, Quadratech Tranny again. Also supplies power to cigar lighter. Plugs into PRNDL switch
John Strenk is offline
post #3 of 4 Old 07-02-2013, 11:30 AM Thread Starter
OrangeCrush79
1979 CJ5
Thanks for the quick reply, since I've not got Quadratec they'll get stuffed back under. Any input on the fuses....any harm in putting a fuse in an un-occupied block if it's currently empty?
post #4 of 4 Old 07-02-2013, 11:54 AM
John Strenk
1976 CJ5
IS there clips to hold it in?
Usually unused positions have no clips.
But no, no problem putting in an extra fuse.
