Help Identify this beautiful CJ please. - Page 2 - JeepForum.com
post #16 of 27 Old 08-24-2011, 10:36 AM
colojeepguy
1970 CJ5
Looks like an M38 to me. Big filler neck opening with hte handle by it, and larger openings in the grille for blackout lights. The windshield looks like CJ2A.
colojeepguy is offline
post #17 of 27 Old 08-25-2011, 09:31 PM
SKT
1981 CJ7
Originally Posted by Mata_Leao View Post
I want to build one just like it.
Here is a link for a lot more Willys Jeep pics - solely for motivation.
http://www.jeepforum.com/forum/f59/willys-pics-718241/
SKT is offline
post #18 of 27 Old 08-25-2011, 10:22 PM
Nailbanger
1946 CJ2A
looks like m38 tub, big hole filer, guages on a seperate panel, 2a winshield, hood. V6 mod, 225 dauntless was real popular, but no way to know as many adapter plates are made.
cool little rig, hi po version of my stock 2a.
I like it. if you put that pic up on the 2a forum pages i'd bet somebody there knows him.
cheers
Rick
ps, looks like a dana 25/23 setup rear is the wartime full floater, axles dont want much more than a v6 on em probably has a t90/ d18 tranny transfer case, pretty solid setup, pretty reliable, kinda scarey over 55 mph! (5:38 stock gears, 4:88's are avail, they do make lockers for both diffs as well), a bit like a 4wd gokart. but partial to em its what i have.(46)
oh and stock brakes welll they just suck, do a disc conversion or at least put 11" drums up front.
if at first you don't succeed, roll it back over, dust it off and try it again.
if the grass is greener on the other side, try waterin your grass.
Nailbanger is offline
post #19 of 27 Old 08-26-2011, 08:18 AM
Pathkiller
1974 CJ5
Could I drive this from Canada to Cape Horn in Argentina?
Seriously? Good luck with that.
Pathkiller is offline
post #20 of 27 Old 08-26-2011, 09:00 AM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by pathkiller
seriously? Good luck with that.
vex could!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #21 of 27 Old 08-26-2011, 09:19 AM
SKT
1981 CJ7
Originally Posted by lucdog View Post
Vex has!
Fixed it for you...
SKT is offline
post #22 of 27 Old 08-26-2011, 09:28 AM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by SKT View Post
Fixed it for you...
Thanks, and as near as I can figure its only 8000 miles from Canada to Cape Horn. Or 123 hours @ 65 MPH.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #23 of 27 Old 08-26-2011, 10:44 AM
SKT
1981 CJ7
Bill
Its a dry heat - cloudless
SKT is offline
post #24 of 27 Old 08-26-2011, 10:58 AM
willp07
1964 CJ5
What nailbanger said looks accurate to me. Also looks like stock suspension setup but lifted, they came with reversed shackles from the factory back then. Also looks like a poer saginaw steering setup. Personally I would also recommend a 225 v6 if you get one, easiest to fit, cause going v8 you have to cut a lot of the body up to squish one in. As for trans, recommend a T18 4 spd / D18 / with a Warn or Saturn OD, makes trips a bit easier. I have an early CJ as well, they are tons of fon, very unique compared to most Jeeps you will see on the road, but take a lot more work and modification to get similiar creature comforts as the newer ones.
willp07 is offline
post #25 of 27 Old 08-26-2011, 11:22 AM
brownbagg
1930 MK Compass
its a little bit of every thing windshield look like 46 cj2, gas filler looks like mb. the grll alougth it has black out turn signal it has cj2/3 headlight and seven slot while mb has nine. The body doesnt look original, too clean, too sharp, no dents look like aftermarket body. But it sure is nice
brownbagg is offline
post #26 of 27 Old 08-26-2011, 11:55 AM
Pathkiller
1974 CJ5
That's not an MB gas filler. The MB had no external gas filler, you filled it directly into the underseat tank. The one pictured is a typical M38 style filler. The grill is also typical M38. The only thing not M38 is the windshield frame, which is CJ2a (although I have no idea how you can pinpoint it to a 46 model year based on that pic).
post #27 of 27 Old 08-26-2011, 11:58 AM
Pathkiller
1974 CJ5
Not correct. The only Jeep with factory reversed shackles was the M38-A1, which this definitely is not. This Jeep appears to be an M38, which had C-shackles at the front, not reversed.
cj , identify , jeep , willys
Beautiful CJ 7 Carmell CJ Jeep CJ Forum 44 12-16-2012 09:27 AM
beautiful original 79 CJ7 on ebay Gregg79CJ7304 Jeep CJ Forum 7 06-29-2011 03:45 AM
I dinged my beautiful CJ! BioTex Jeep CJ Forum 2 04-21-2009 04:10 PM
selling a beautiful cj7... tell me if i should trade for this cj5 LostINohiO Jeep CJ Forum 61 12-13-2008 07:17 AM
Its A Beautiful Day NHwheelin Jeep CJ Forum 2 03-19-2008 09:42 PM
