Help I think my PCM is bad on my 4.0L ? - JeepForum.com
post #1 of 12 Old 07-15-2015, 07:44 AM Thread Starter
chucker2
1981 CJ7
Ive had a start issue and assumed it was the starter switch down on the steering column. I installed a new one. This was not it. I installed new relays both the ASD relay and Fuel pump relay thinking one or the other or both were bad. Still not it, wont start. Fuel pump is silent so relay is not getting pulled in.
Do i need to check the CPS?
I have a 95 OBD1 engine with Hesco harmonic balancer mounted CPS.
If this checks ok can it be a BAD PCM ?
I hooked up a code scanner and I get " no connection to vehicle". It always scanned before, but now nothing.
How does the PCM get power through the ignition switch? I can take a volt ohm meter and check the pins for voltage?
thanks chuck
81 CJ7 Renegade, Mocha Brown Metallic and Tan, 4.0L w/ T-5, RE 2.5 Lift, 31 BFG's on Wagon Wheels
chucker2 is offline
post #2 of 12 Old 07-15-2015, 08:22 AM
Mike Romain
You would be better off in the YJ forum. They are used to pcm issues. No codes is one symptom of the 15 capacitors blowing out and there are test points to verify that.
Mike
Mike Romain is offline
post #3 of 12 Old 07-15-2015, 10:54 AM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
Check engine light ever flash on when you initially turn the key ON before cranking? If no, then ECM not getting power. Pin 3 should have power all the time. If no power, then fuse or open wire.
Another schematic specifically for 95' Wrangler. Muddier to read. Same as above.
Shaun
1978 CJ5 to CJ6 - Build in progress......
TIPPEDITOVER is offline
post #4 of 12 Old 07-15-2015, 03:32 PM Thread Starter
chucker2
1981 CJ7
Here is what I know. Pin 3 is "hot" at steady state, ignition off....With ignition on pin 9 is "hot"..... also With ignition on pin 51 is "hot" (ASD Relay control)
i cant get # 32 to register anything, its dead. Its the MIL wire and it should be giving some kind of voltage??
chucker
chucker2 is offline
post #5 of 12 Old 07-15-2015, 05:52 PM
TIPPEDITOVER
In the Lab
1978 CJ5
Ok, that's good info. Interesting. Pin 32 should have power when key is on (I think). ECM provides ground to work the light (I think-not the other way around). Bulb is missing, no good or open wiring. If that doesn't help, here is info on the bad capacitors Mike mentioned.
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
It's not a dead CPS because you would still get fuel pump prime if that's all it was. You're not getting prime, so CPS is out.
Shaun
post #6 of 12 Old 07-15-2015, 05:56 PM Thread Starter
chucker2
1981 CJ7
No shaun, the mil is not hooked up. its being a cj7 and originality on the dash was my goal. i just scan it when it runs bad, but i agree it should be throwin codes?
i think my pcm is bad ?
chuck
chucker2 is offline
post #7 of 12 Old 07-15-2015, 06:00 PM
TIPPEDITOVER
In the Lab
1978 CJ5
It's looking like it could be bad.
Shaun
post #8 of 12 Old 07-16-2015, 04:49 AM
Mike Romain
chuck
At least those pcm's are a cheap and easy rebuild. Having a mil light helps diagnose things though, you could even have one tucked up under the dash.
Mike
post #9 of 12 Old 07-16-2015, 05:36 PM Thread Starter
chucker2
1981 CJ7
Well I put in my new ( rebuilt )Pcm and still no start. Won't even crank. Fuel pump charged, then it tripped the ASD. My clock stopped, then started in a few minutes.
Maybe a short in the ignition switch?
I'm just like a dealer mechanic now!! PARTS CHANGER!!
Chuck
chucker2 is offline
post #10 of 12 Old 07-16-2015, 07:16 PM
Mike Romain
You sure could be describing a bad connection on a main battery cable. I think I would clean them not forgetting cables have 2 ends.
Mike
post #11 of 12 Old 07-16-2015, 07:26 PM Thread Starter
chucker2
1981 CJ7
ok mike, I will check contacts, then fuel, spark, etc. Basics....
chucker2 is offline
post #12 of 12 Old 07-18-2015, 06:16 PM Thread Starter
chucker2
1981 CJ7
Well I finally changed the starter and that was it after I put a new brain, Pcm.
And tightened the hell out of all the cables Good contact.
Chuck
chucker2 is offline
