Help - I need a measurement on a CJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Help - I need a measurement on a CJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 11-26-2014, 08:40 PM   #1
PanteraPilot
1978 CJ5
I'm looking for a measurement on a stock shackle (front and rear) on a CJ5/7. I have a 1978 and the measurement needs to be the distance between eyeholes on the shackles (upper and lower holes). I'm trying to figure out how much shackle the PO put in my CJ5. Its a V8 if that makes a difference. Thanks.
PanteraPilot is offline   Reply With Quote Quick reply to this message
Unread 11-26-2014, 08:41 PM   #2
only in a jeep cj
3 inches
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote Quick reply to this message
Unread 11-27-2014, 10:58 AM   #3
PanteraPilot
1978 CJ5
And its the same front and back? I have 4-3/4 in the front and 6-1/2 in the back. The Jeep sits level. It was my assumption that the springs were stock.
Unread 11-29-2014, 06:13 AM   #4
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yes, front and back are the same in stock form.
Shackle lifts are the cheap and lazy way to run bigger tires. The problem is, longer shackles on the front reduces the caster angle, causing squirrelly handling, unless other modifications are made They also reduce approach angles on obstacles.
Generally speaking, anything over 4" is not advised on a CJ.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
