HELP!! I need help understanding how a oversize 21 gallon tank hooks up! - JeepForum.com
post #1 of 5 Old 03-27-2004, 11:08 PM Thread Starter
CJman77
1977 CJ7
Okay I am a bit baffled but I have yet to pull out my old one so that may answer a few of my questions.
1. There are two brass outlets on the left side of the tank. I know one goes to the engine fuel pump where does the other go? I know one isn't a vent because the vent and the fill are next to each other.
2. The Metal Brackets the "extend the skid plate"? How do they attach? This seems puzzeling!
3. Finally the damn strap that "goes across the top" seems way to damn big to fit over the tank?
If anyone has any in sight I would appreciate it but I do think its BS that this gas tank upgrade came with basically no directions I mean I have a sheet with maybe a paragraph of writing on it. Pretty damn pathetic what happened to detailed directions with pictures?
LOL
Brian
CJman77 is offline
post #2 of 5 Old 03-28-2004, 07:12 AM
hotmix
hotmix's Avatar
I don't know anything about the straps or mounting but the other fitting is for the fuel return from the fuel pump.
Jim Pierce
www.hotmixstudio.com
hotmix is offline
post #3 of 5 Old 03-28-2004, 08:16 AM Thread Starter
CJman77
1977 CJ7
Yeah but there isn't a return on my fuel pump? Its a small block chevy and no place for a return on it.
CJman77 is offline
post #4 of 5 Old 03-29-2004, 06:29 PM
rwcloukey
when you drop your old fuel tank in this case it should be blocked off. What Im saying is that your orig. tank has those same fittings so just hook up whatever is already there to your new one. But Im pretty sure it should be blocked. As far as the rest cant help ya
81 cj7.
I6
herced tub
diamond dash
rwcloukey is offline
post #5 of 5 Old 03-30-2004, 12:11 PM
MR.CJ-7
The return comes from the fuel filter. If you get one for a stock CJ (mine is an AMC 304) it will have one inlet(pump side) and two outlets(carb side) The feed to the carb is the larger diameter, the smaller diameter returns to the tank. Make sure the return is oriented facing up.
Former CJ'er
MR.CJ-7 is offline
Aero Tank 26 gallon gas tank?? texashighridin Jeep CJ Forum 10 10-04-2009 01:05 PM
21 Gallon Tank... Is this all I need? elks96 Jeep CJ Forum 3 02-25-2009 06:23 AM
Best oversize gas tank MeCasa Jeep CJ Forum 1 07-21-2006 09:47 AM
20 Gallon Gas Tank on a CJ7? coppertop1226 Jeep CJ Forum 6 07-10-2004 09:29 PM
20 gallon tank bolt up ? Booner8269 Jeep CJ Forum 4 01-07-2004 11:48 PM
