Help - I'm stumped - ignition issues - JeepForum.com
post #1 of 26 Old 08-31-2013, 10:45 AM Thread Starter
82Renegade
1982 CJ7
Appreciate any help on this- I'm pulling my hair out. CJ has been running strong for years since any changes were last made to the ignition or TBI systems. The other day it randomly wouldn't start, and in troubleshooting seems I'm not getting spark to the cylinders. I AM getting spark from the coil into the distributor cap. I've tried changing the cap and rotor, but no dice. I've tested the pickup coil and its right on at 650ohm. What else could it be?
82CJ7, Howell TBI, Ford e-coil, MSD 6A ignition
Thanks!
82Renegade is offline
post #2 of 26 Old 08-31-2013, 10:48 AM Thread Starter
82Renegade
1982 CJ7
Any also, let me note that the fuel injectors are firing, so I don't think its an ECM issue.
post #3 of 26 Old 08-31-2013, 01:42 PM
LumpyGrits
Not much on FI.
This is SWAG on my part. Have you tested the CPS and fuel psi?
Ever change the fuel filter?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 26 Old 08-31-2013, 05:45 PM
petey156
So you have fuel and spark, But it still does not. Fire?
Have you checked for spark at the plugs?
Are the plugs. Damp with fuel or fouled?
petey156 is offline
post #5 of 26 Old 09-01-2013, 12:20 AM
W7NB
Check your fuel pump. Seems like the most common problem on TBI converted rigs.
°lllll° Am I broke yet??
1985 CJ7 With HO 4.0 Conversion
2013 JK
W7NB is offline
post #6 of 26 Old 09-01-2013, 12:31 AM
titomars
1981 CJ7
What is SWAG?
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #7 of 26 Old 09-01-2013, 07:48 AM
WindKnot
1977 CJ7
Sophisticated Wild @ssed Guess. It's very scientific. (And usually right)
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #8 of 26 Old 09-01-2013, 09:19 AM
LumpyGrits
Originally Posted by titomars View Post
What is SWAG?
It's 'Jeep' speak,,,,,,,,
LG
post #9 of 26 Old 09-01-2013, 11:15 AM
gmakra
gmakra is offline
post #10 of 26 Old 09-06-2013, 03:30 PM Thread Starter
82Renegade
1982 CJ7
MSD tests ok. I also get spark out of the coil into the distributor. Just because I can't figure out what else it could be, I just replaced the distributor, cap/rotor, plugs and wires. Still no go. Plenty of gas in the carb, just no spark. What else could it be? Pulling my hair out.
post #11 of 26 Old 09-06-2013, 03:35 PM
LumpyGrits
Did you test the module in the dizzy?
LG
post #12 of 26 Old 09-06-2013, 03:48 PM
jeepwhore
Spark is leaving the coil but I didn't see where you checked to make sure the plugs are actually sparking. If they aren't I'm thinking pooched distributor drive gear or cam gear maybe.
Disconnect the coil from the dizzy, take the cap off and turn it over to make sure the rotor is turning.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #13 of 26 Old 09-06-2013, 03:55 PM
LumpyGrits
Hmmmmmmm, OP replaced the whole dizzy........Maybe it wasn't 'indexed' correctly on the install and is waaaaaaaaay out of time.
Easy enough to do........
LG
post #14 of 26 Old 09-06-2013, 04:55 PM
jeepwhore
LG
That was my next thought. If the rotor is turning and the plugs are sparking it could be timing related (chain jumped/broken etc.)
I don't know TBI's but what effect would it have if the centrifugal advance that is normally disabled for these swaps suddenly started working again?.....assuming the OP used the stock dizzy and locked down the advance.
post #15 of 26 Old 09-10-2013, 07:59 AM Thread Starter
82Renegade
1982 CJ7
I am confident I have the new dizzy aligned properly. I'm completely out of ideas on what to do.
In summary: Jeep was running great, with no changes being made just stopped firing up. Testing yielded that it was a spark issue.
Have replaced, coil, distributor, cap, rotor, plugs & wires
Testing confirms getting spark out of coil into disty
No spark at plugs
Distributor has a good ground
What am I missing? It has to be something minor- what wire could be loose or poorly grounded?
