Help with hei please! - JeepForum.com
post #1 of 4 Old 04-22-2013, 06:10 PM Thread Starter
firemanjim7
1983 CJ7
Well I change my dizzy over to CRT hei. I thought I did everything per the instructions. It started up sounded like a tractor running so I checked spark at every plug, got it. So I decided to kill it and it kept running WTF! So I pulled the pink batt wire and it died. Any thoughts?
firemanjim7 is offline
post #2 of 4 Old 04-22-2013, 06:45 PM
jeepwhore
Is your hei power coming through a relay? If you've wired the hei exactly as instructed then you may need to add a diode to the alternator wire as it may be back feeding the ignition.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 4 Old 04-22-2013, 06:48 PM Thread Starter
firemanjim7
1983 CJ7
I'm through a relay. I'll check right quick.
post #4 of 4 Old 04-22-2013, 06:52 PM Thread Starter
firemanjim7
1983 CJ7
That was it thanks. Btw it was way retard that's why it sounded like a tractor.
