Help with this heater box part please? - JeepForum.com
post #1 of 9 Old 02-09-2013, 03:35 PM Thread Starter
smokedog
Can anyone help me with the name of this part on the right side of the heater box (gasket??) and possibly where I can get a new one?
Smokedog - Brandon, MS
84' CJ7 Renegade - Tungsten grey metallic paint, 388ci Chevy, 700r4, D300, SOA lift with YJ springs, 1" body lift, Bilstein 5150 shocks, Currie Rock Crawler Shackles, Trussed Ford 9 Rear w/ 4:56 gears, Detroit lockers, Dana 44 front, full poison spyder cage and lots of chrome and stainless.
smokedog is offline
post #2 of 9 Old 02-09-2013, 03:39 PM
243
1978 FSJ Cherokee
If I recall, that gasket is no longer made, I used self-adhesive 1" x 1/4" thick high density weatherstrip.
Dave's 78 Build
243 is offline
post #3 of 9 Old 02-09-2013, 04:30 PM
bdb86cj
http://www.mcmaster.com/#
Go to the McMaster Carr website, pick out a sheet of foam that appeals to you needs and cut your own.
Hull# 190
bdb86cj is offline
post #4 of 9 Old 02-09-2013, 04:38 PM Thread Starter
smokedog
Thanks guys. I'll try and make my own. And on a side note the upper and lower piece are not held together other than their mounting location right? In other words the gasket where the two pieces doesn't have to be mounted together but rather the upper just sits in the gasket on the lower?
smokedog is offline
post #5 of 9 Old 02-09-2013, 06:17 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
ditto.. I just made my own.. easier, and cheaper..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #6 of 9 Old 02-09-2013, 10:40 PM
248107
Guest
1983 CJ7
I just used a piece of Truck Topper Tape.You put it between the topper and the truck bed to seal it.Got anyone close that installs or sells toppers?They might give you enough to do it or maybe a body shop
248107 is offline
post #7 of 9 Old 02-10-2013, 08:37 AM
aallison28
Or go to Home Depot where they sell the window and door sealing stuff.
aallison28 is offline
post #8 of 9 Old 02-10-2013, 08:46 AM
243
1978 FSJ Cherokee
The truck cap tape I found was white or light gray, the high density polyurethane weatherstrip I recommended is black.
Dave's 78 Build
243 is offline
post #9 of 9 Old 02-11-2013, 09:51 AM Thread Starter
smokedog
I ended up buying 1' x 1/4' self adhesive rubber weatherstripping and it did the job. I also bought a can of spray foam insulation to fill in the gaps (if any) but didn't end up needing it. Thanks guys for the help and hopefully this will help someone else down the road. Now I have to finish putting this beast back together.
smokedog is offline
