Help! Fuel flow problem... - JeepForum.com
post #1 of 7 Old 05-11-2013, 03:24 PM Thread Starter
Melchior
1980 CJ5
I'm having no fuel getting to the fuel filter.. installed new fuel pump and blasted fuel line with air compressor.. what else is left? Could it be something with the sending unit?
Melchior is offline
post #2 of 7 Old 05-11-2013, 03:37 PM
LumpyGrits
Did you mess with the fuel tank or system of late?
Take your gas cap off and check flow again.
Are you SURE there is any fuel in the tank?
LG
LumpyGrits is offline
post #3 of 7 Old 05-11-2013, 03:42 PM
hp_lovecraft
1981 CJ5
You could trying running a small hose to a gas can near the fuel pump, then turn over the engine to see if it pulls gas.
I had a problem years ago where no fuel was getting to the carb. But when I by passed the tank, etc, it worked fine. Turned out that when I had dropped the tank to replace the sender, I pinched the fuel line when reintalling the tank. Maybe you can a cut/hole in the line, and its sucking air?
hp_lovecraft is offline
post #4 of 7 Old 05-11-2013, 05:33 PM
roboto65
1976 CJ5
I had a problem like this I would put fuel in the carb the eng would run till it died but the fuelpump would not pump fill the bowl on the carb figured I would drive it back it up just to check the trans rebuild I had done and, walla the fuelpump started working not sure why if it had any thing to do with movement or what but it has run fine since.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #5 of 7 Old 05-11-2013, 07:09 PM Thread Starter
Melchior
1980 CJ5
Thanks, I'm going to give this a try tomorrow!
Melchior is offline
post #6 of 7 Old 05-12-2013, 07:34 PM Thread Starter
Melchior
1980 CJ5
OK so the fuel trick worked, so i'm assuming I must've been sucking air from somewhere...
Melchior is offline
post #7 of 7 Old 05-13-2013, 06:27 AM
Caish
1987 XJ Cherokee
Mines alot older than yours, but I had an issue with a cracked fuel line.
The line is a hard semi-flexible plastic and my was cracked nearly in two.
Allowing it to suck air.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
