Help with front left signal lamp!!! (84 CJ7) - JeepForum.com
post #1 of 10 Old 01-10-2002, 08:32 PM Thread Starter
AeroViper1
Post Help with front left signal lamp!!! (84 CJ7)
I can't figure out what's going on...here's the situation; Just put a Centech wiring harness on my 84 CJ7...Everything is working great...but my left blinker won't blink. The rear blinker blinks and the parking light works in the front but when signaling it won't come on...I've checked the plug with a meter for power and it is deffinatly sending the signal to blink...not the bulb, not the light fixture, I switched it with the right side one that was working fine and it worked on the right side but the left still didn't work...HELP
AeroViper1 is offline
post #2 of 10 Old 01-11-2002, 02:35 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
Got Ground ? -
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #3 of 10 Old 01-14-2002, 05:57 AM
Bulletproofcj7
Post
I put a centech harness in my cj7,they have a great tech support dept. they can answer any questions you have and they will walk you through it.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #4 of 10 Old 01-14-2002, 07:24 PM Thread Starter
AeroViper1
Post
I don't know how I could ground it any better than I am...Centech does have a good Tech dept....But they didn't know on this one...not a single person knows how to fix this problem.
post #5 of 10 Old 01-28-2002, 11:56 AM
Jeep Daddy
Jeep Daddy's Avatar
Post
Please let me know when you find out. I've got the same issue with the left rear turn signal/brake light. Good wire to fuse block and bulb good. I've ordered a new turn signal switch because in the diagram that seems to be the only place that it's not making contact. The turn signal flasher works, the front signals works - I know that my ground sucks, but I'm going to install new battery cables with a ground strap soon.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #6 of 10 Old 01-28-2002, 08:21 PM
dirtystyle
Post
um ,,,,,, buy a multi meter you need power and ground start at fixture and work your way in
" if it wasn't a little dirty it wouldn't be fun "
dirtystyle is offline
post #7 of 10 Old 01-29-2002, 05:12 PM Thread Starter
AeroViper1
Post
I honestly have no clue...when I probed it with the Multi-meter...it was fine...when I connected it, the current went from up,down,up,down to a constant 12v. I have no idea what happened but it fixed itself...make sure you probe it and find a good ground...I still don't know what was wrong with mine but if I ever find out i'll let you know
post #8 of 10 Old 01-30-2002, 10:48 AM
Dustin Maschino
Post
You could always run a wire from your tail light up to the front and it'd work ok, but it'd also come on evertime you hit the brakes...
Dustin Maschino is offline
post #9 of 10 Old 01-30-2002, 11:41 AM
Jeep Daddy
Jeep Daddy's Avatar
Post
It so happens that the brake light on the left rear also does not work. They use the same fillament in the bulb - I believe. I'm going to try applying 12V to the wire and see if it lights the bulb. If it does, then the problem will be somewhere under the dash, on up to the column or turn signal switch.
post #10 of 10 Old 02-12-2002, 10:27 AM
Jeep Daddy
Jeep Daddy's Avatar
Thumbs up
I found my problem. One wire on the turn signal switch was modified by PO who didn't know what the heck he was doing. I guess he tried to use this wire to tap into the lights for towing purposes. I soldered the wire back the way it should be, sprayed some WD40 on the turn signal switch, blew it all off good with air and it all works perfect now.
Left turn signal won't blink meater Jeep CJ Forum 5 12-21-2009 09:01 PM
left turn signal prob 76cj360ci Jeep CJ Forum 4 04-20-2009 08:38 PM
Left turn signal does not work Axlesnap Jeep CJ Forum 8 02-03-2009 06:16 AM
Left turn signal? bodge Jeep CJ Forum 4 09-23-2007 05:32 AM
left turn signal? b grau Jeep CJ Forum 4 09-30-2005 09:01 AM
