HELP electrical issue - JeepForum.com
post #1 of 9 Old 04-25-2013, 02:00 PM Thread Starter
sullyde79
1975 CJ5
I have a 75 CJ5 with a new altinator. The jeep will start with the battery connected but won't stay running once the battery is disconnected. It dies instantly. The only other symptom is that the headlights stopped working. I don't know if these problems are connected or not. Any info would be greatly apprectiated.
Thanks
sullyde79 is offline
post #2 of 9 Old 04-26-2013, 08:37 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
question, why would you disconnect your battery after you've started the engine? if I remember correctly, when my battery blew out, the motor died when the charge was gone... the alternator in itself will not keep your engine running..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #3 of 9 Old 04-27-2013, 02:37 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Actually it will keep running with the battery disconnected. The battery is just a storage device and the Jeep actually runs on the alternator most of the time. If you have an ammeter you would see that the battery practily puts out nothing when the engine is running.
It's a quick way of making sure the alternator is working.
I'm thinking they may not be connected, Headlights and engine running that is but..
Have you checked the firewall plug, if you have one, to see if it's tight?
John Strenk is offline
post #4 of 9 Old 04-27-2013, 06:56 AM Thread Starter
sullyde79
1975 CJ5
My firewall plug looks like a hot mess and I can't find a place to order a new one. Thanks for pointing me in the right direction.
post #5 of 9 Old 04-27-2013, 07:36 AM
John Strenk
1976 CJ5
You could rebuild it if it's not all melted apart..
Terminals are easily available.
post #6 of 9 Old 04-27-2013, 01:26 PM Thread Starter
sullyde79
1975 CJ5
It appears to be in one piece, but it's all gummy inside. I should be able to clean it out.
post #7 of 9 Old 04-27-2013, 01:28 PM
jodowii2
1980 CJ7
The gooey stuff is di electric grease to kep water out
jodowii2 is offline
post #8 of 9 Old 04-27-2013, 05:25 PM Thread Starter
sullyde79
1975 CJ5
I did a simple test and it was blocking the circuit. its more like tar. I used a test light. If I touched it no light, if I scraped it away some, light.
post #9 of 9 Old 04-27-2013, 08:10 PM Thread Starter
sullyde79
1975 CJ5
The headlights were not a symptom after all. That was a loose connection. I haven't been able to check to see if it'll stay running yet. Sleeping 2 year old. But thank you for the help.
