02-21-2012, 03:45 PM
#16
also my rear tires are rubbing hard on the frame with little flex on the suspension.....
02-21-2012, 03:51 PM
#17
I'm tellin you man.. those Spidertrax spacers will fix your problems.
02-21-2012, 03:53 PM
#18
Originally Posted by Masterbrent07
so do guys with super wide tires on CJ's have just a really ****ty turning radius?
Edit: I'm too slow on the keyboard. It was already covered.
02-21-2012, 04:23 PM
#19
I suggest you start with what offset your stock wheels are/were. Use this chart as a guide https://www.rsracing.com/tech-wheel.html#backspace to figure out where you need to be with the new wheel offset. You got what sounds like the right wheel size. You've got what appears to be about 4" of backspacing, a little too much.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
02-21-2012, 04:31 PM
#20
soooo what I'm getting outta this is
#1 i should not rely on discount to help me pick out wheels and tires.... (sry guys my bad) also i should have reworded the term "screwing me" from the title of this thread to i need help finding the right wheel lol.
#2 adjust my wheel stops. but that's not gonna help the back tires form rubbing on the frame under flex....
#3 BUY wheel spacers and that will fix all my problems
#4 NO ONE has an opinion on what wheel i can run that has a larger -offset/ smaller backspacing
so one last time.... does anyone have a wheel suggestion for a wheel that has " serious offset"?
02-21-2012, 05:19 PM
#21
You'll be hard pressed to find any wheels with less than 3.5" of back spacing. That's only 1/2 of clearance from what you have.
I run 35x12.50 tires on narrow track axles with 1.5" spacers and don't have any rubbing issues.
78 CJ7 258 Auto Q-trac SOA 35" General Grabbers.
02-21-2012, 05:26 PM
#22
I have 36x14.5R15 mt bajas on 15x12 mt classic II's w/ 3.5" backspaceing with no rubbing on my nt axles... My stops are adjusted a little and I have tons of flex.
1979 CJ5 408 AMC, Holley truck avenger 770, T15, Dana 20, custom ford 9" w/ strange axles, Dana 44 front, 8" of lift, custom fenders, Hedman headers, 36x14.5 MT baja
1988 YJ 4.0 FI, AX-15 5spd. NP231 4" RC lift 1" shackles 33x12.5R15 Firestone Destination MT Ford 8.8 w/ 4.10 gears no TB or SB
ASE certified Auto Tech
NRA lifer USN/ss Run Silent, Run Deep!
02-21-2012, 05:30 PM
#23
I wanted to give Discount Tire another thumbsup to offset the title.
02-21-2012, 05:36 PM
#24
I've got 10.5's and I always have to do 3pt turns on the average street, unless I pop the curb on both sides.
Custom CJ dash lamps: "Check Engine," "Fog Lights," "Front" & "Rear Locker," "Winch Power" and others:
http://www.jeepforum.com/forum/f128/custom-cj-dash-lamps-lockers-winch-check-engine-fog-lights-1332203/
02-21-2012, 06:22 PM
#25
My Scrambler will out turn most shorter CJs, It turns great, but I'm running custom Dana 44s that are 58" wide. That gives me plenty of clearance to turn and not hit the springs.
John N
02-21-2012, 06:32 PM
#26
you need to face the fact that the tire and wheel combo you have can and will fit almost everyone's CJ. The fact that they don't fit yours is no one else's fault. In light of the easy fixes that everyone has given you, you need to just put on your Big Boy Pants, contact a Moderator and ask him to modify your Post title to keep you from sounding like a   .
Trying to stay cool here but I personally know the store in San Marcos and the manager and I'm calling BS on that statement.
Finally, advice and help are more easily given if you fill out your profile......
If it's good TO you, it's gotta be good FOR you....
02-21-2012, 06:53 PM
#27
+1 vote to change title or delete post.
We're too quick to knock vendors and not quick enough to give them credit.
02-21-2012, 07:08 PM
#28
02-21-2012, 07:44 PM
#29
I ALWAYS buy my tires from Discount Tire, and whenever I buy anything larger than stock, they make sure to explicitly tell me they are not responsible if I have problems..
02-21-2012, 07:55 PM
#30
Over it
I aired down to far this weekend and busted a bead. It was full of mud they cleaned it balanced it and put it back on for no charge.
Edit: I have not purchased anything from them but I will when I need tires.
LJ Owners Group member #431.
