help determining condition of 258 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > help determining condition of 258
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 03-03-2015, 02:56 PM   #1
jeepdog571
1983 CJ7
While i have my engine out im going to paint it. I removed to manifolds and while looking at the intake valves i noticed they have alot of carbon build up. According to the po it is a remanufactured engine with about 26000 miles on it. I wonder if its not and its the original engine. Is this carbon normal? Should i remove the head and take it to a machine shop to clean it up. Everything looks pretty clean under the valve cover. Also it ran great before i removed it. What should i look for when i remove the oil pan as far as excessive wear? I just want to make sure its good to go before i start painting it. Thanks
jeepdog571 is online now   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:17 PM   #2
captkhaos
1980 CJ7
Well, you probably should have taken a compression test before you pulled it. I guess you could do a leak down test now that it's out. I don't see anything in the pics that require pulling the head. I wouldn't pull the pan either unless it's leaking. You're not gonna be able to "look" at anything in there. How was the oil pressure? How did the plugs look?
captkhaos is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:18 PM   #3
macscal
1978 CJ5
If it ran great, go with it.
Your pics don't show me (in my limited kknowledge) to be concerned about
Sent from my VS840 4G using JeepForum
macscal is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:25 PM   #4
swatson454
swatson454's Avatar
1983 CJ7
Put the valve cover back on, buddy. That's a pretty fresh engine. The occasional bottle of fuel injector cleaner might not hurt but I see nothing there to be remotely concerned about.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:29 PM   #5
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm certainly no expert, but the carbon buildup doesn't look excessive compared to what I've seen.
While you have the valve cover off, and if you have a dial indicator, you could check a few things before going any deeper, including:
1. Valve stem/guide clearance
2. Cam Lobe lift
3. Valve timing
Of course, a compression and/or leak down test would have given you a good indication of wear on the engine. Again, this would not require any further disassembly.
How did she run before you pulled it? Burn any oil? How was the power? Any noises or strange performance?
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 03:53 PM   #6
jeepdog571
1983 CJ7
When i first got it she was an oily mess but ran fine. I cleaned it up fixed the leaks and rebuilt the carb and it ran even better. I do not know if it burned any oil because i only drove it around a few times before i took it apart. I never heard it knock and never saw any smoke. That was 2 years ago. I started off just wanting to fix some rust and drive it. Now its turned into a full project. I couldnt stop taking it apart. Im sure you guys know what i mean. Well since ive taking this off i might as well replace this and while this is off i might as well take this off to and replace that. And it just kept going. I guess i should check into the leak down test . Here is another pic. It has a nice chunk on it. Im just itching to clean it.
Unread 03-03-2015, 03:57 PM   #7
Matt1981CJ7
1981 CJ7
Welcome to the CJ rabbit's hole.
We've all stepped into it at some point.
Matt
Unread 03-03-2015, 04:24 PM   #8
Mortgage-payer
1976 CJ7
If the starter and flywheel are still on the motor, you can cobble together some sort of starting system with a battery, switch and starter relay. Then do a compression test.
I call it a distributor, not a dizzy.
Mortgage-payer is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 04:40 PM   #9
Rebel442
Matt
Yup after you pull the head to clean it up your gonna start thinking it might not be a bad time for new bearings after all your so close, and those rings are right there.......... and on.....and on.......... and on..........................
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 06:08 PM   #10
hunter1
Junior Member
1979 CJ5
Allow me to give you a benchmark... the way mine looked when I first got it.
1979 CJ5, replacement 258(build date Jun83), Dana30, T-18a, Dana20, AMC20
hunter1 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 06:38 PM   #11
jeepdog571
1983 CJ7
The only thing stopping me now is my wife.
Unread 03-03-2015, 06:39 PM   #12
jeepdog571
1983 CJ7
Wow thats pretty dirty. I guess I have it alot better than I thought. Thanks for the pic.
Unread 03-03-2015, 06:51 PM   #13
Blutarsky
Blutarsky's Avatar
1982 CJ7
I'm no expert. If you look at page 3 of my project 2 thread I have a photo or two of doing a compression test on my 258. I had someone with skill and knowledge helping me. It wasn't difficult.
Blutarsky is offline   Reply With Quote Quick reply to this message
Unread 03-04-2015, 03:23 AM   #14
gmakra
I would do a leak down test and that can be done the way the engine sits now.
gmakra is offline   Reply With Quote Quick reply to this message
