Help! Battery tipped over yesterday, discovered today :( - JeepForum.com
post #1 of 6 Old 09-08-2009, 07:20 PM Thread Starter
dobber_spe
1981 CJ5
I went out to my garage today and popped the hood. Unfortunately, my new battery flipped over yesterday when wheeling. Of course it leaked quite a bit overnight. Mostly it leaked through to the cardboard on the floor, but did manage to soak the left front springs. I took off the neg. lead immediately and cleaned up a bit with a shop rag. Should I be concerned about anything else and is the battery shot now or can I just add some distilled water?
Thanks!
-Dave
dobber_spe is offline
post #2 of 6 Old 09-08-2009, 07:34 PM
a2tripp
1993 XJ Cherokee
i think its a hydrometer you want to check your battery with, here we can take it to napa and they will check it and they will put the proper acid/water, pretty cheap too.
93 cheromanche
a2tripp is offline
post #3 of 6 Old 09-08-2009, 07:56 PM Thread Starter
dobber_spe
1981 CJ5
sounds good, I am sure autozone where I bought can check it. Thanks!
-Dave
post #4 of 6 Old 09-08-2009, 08:17 PM
frankush
Make up a solution of baking soda and water in a large bucket. Use this to rinse off anywhere the battery acid may have gotten into, when it spilled. It will neutralize the acid. Let it sit for a couple minutes, then rinse with a hose. Battery hold downs are installed so this doesn't happen.
frankush is offline
post #5 of 6 Old 09-08-2009, 09:13 PM Thread Starter
dobber_spe
1981 CJ5
Fankush, thanks for the info. The battery was secured in tray, but no tie-downs in my old CJ. Trust me, I learned my lesson, it'll be bungeed in until I find a better solution!
-Dave
post #6 of 6 Old 09-08-2009, 10:56 PM
frankush
Every auto parts store has those universal battery hold down kits and the best part is they're cheap!
frankush is offline
Battery gauge reading low: Old battery died and still reads low with new battery jatepper Jeep CJ Forum 16 08-30-2009 02:25 PM
New Battery, New wiring... draining battery dead. HELP!!! CoyJ-5 Jeep CJ Forum 7 07-31-2009 07:54 AM
Battery being drained while car is running??? Car off, I believe battery is good! Jeap Jeep CJ Forum 2 11-09-2008 06:31 AM
yesterday gas gauge worked today it doesnt rodjr Jeep CJ Forum 3 10-15-2008 09:05 PM
Dirty Axle Tubes (inside) discovered during one piece swap CJPoorhouse Jeep CJ Forum 2 07-31-2004 03:12 PM
