Help after the carb rebuild... - JeepForum.com
post #1 of 9 Old 01-16-2010, 05:20 PM Thread Starter
pcg7384
1981 CJ7
I just kitted my Carter 2bbl BBD carb and now it has issues (more so than before). The mixture screws don't seem to do anything and when I drive it, it will idle for about 30 seconds before it chokes to death. I opened up the hood and it's leaking gas from one bottom gaskets (new) and is dripping gas into the bowl after the motor is off for a good 5 min. I can hear a gurgling sound which I assume is gas continuing to trickle into the carb.
When doing the kit I followed the instructions and thought I re-adjusted everything but I guess not. I haven't thrown anything away so I could easily put the old parts back on. The concerns I have are the float and pump adjustments.
pcg7384 is offline
post #2 of 9 Old 01-16-2010, 05:41 PM
baldfatdad
1984 CJ8
how did you clean the carb?
baldfatdad is offline
post #3 of 9 Old 01-16-2010, 06:17 PM Thread Starter
pcg7384
1981 CJ7
carb cleaner in the can
pcg7384 is offline
post #4 of 9 Old 01-16-2010, 08:08 PM
baldfatdad
1984 CJ8
you need to get a carb cleaning kit. Comes in a gallon can. It has a basket in it to put parts. Follow the instuctions to the letter. Blow the carb clean with air when you're done. Then re-read the carb kit assemblu instructions and follow them exactly. Do things in the steps they tell you. Don't go out of sequence.
You also need to check the base and upper part of the carb for flatness. 800 grit sand paper layed on a piece of glass (glass is a flat surface), Make figure 8's with the part, then check the wear pattern to make sure its flat. This or the gasket being in backwards or upside down could be the leak at the base.
TAKE YOUR TIME. IF it doesn't work, leave it a day and do it again. Sometimes it helps to have someone else read the instuctions to you. I use to have my kid do it. He learned to read and I got to look at the stuff while I listened to the instuctions.
post #5 of 9 Old 01-16-2010, 08:20 PM
shok47
1983 CJ7
don't forget to be easy on the wrenches, the nuts and bolts only take like 10lb/ft. Just if you didnt know
shok47 is offline
post #6 of 9 Old 01-16-2010, 08:42 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Usually if the mix adjust screws don't change anything then the idle is too high - the throttle blades are open far enough that the carb is in the transition circuit, which 'overpowers' the idle ckt. The Idle may have to be so high because of the extra fuel being dumped into the engine from the leaks. Verify the float levels too - aren't these the carbs that the fuel line attachment fitting is also the float adjustment?
Rick
Cutlass327 is offline
post #7 of 9 Old 01-17-2010, 04:19 AM
Dngrs1
1979 CJ7
When I rebuilt my BBD I found out that the idle mixture screws were two different sizes. Take them out and look at the holes to make sure. One was short and fat, the other longer and skinny.
Dngrs1 is offline
post #8 of 9 Old 01-17-2010, 06:04 AM
Mike Romain
To get the 'best' help in a forum, you should make one thread per problem. You now have 3 going on per problem.... Folks don't always see the other threads so don't know what the history is or what has been tried already or what you found 'broken'....
I have been cleaning and kitting carbs for years and haven't ever use a dip pot, I only have access to the spray carb cleaner usually. Be wary, there is a 'throttle body' cleaner as well as a 'carb' cleaner. They don't mix and match well, the TB cleaner won't work well on a carb and the carb cleaner will dissolve a TB.
First thought is the float level is way too high. well, it has to be to have gas pouring like you describe. Did you need to adjust it much? Usually they need very little adjustment. Did you have any issues putting the new float needle and seat in?
You also need to use two wrenches when putting on the gas line or you will mess up the float level pretty bad. The fitting in the carb has to be held from moving when the gas line gets tightened on but this usually makes the float too low so may not be any issue to you.
You have to be exact and kinda gentle when doing things like the vacuum piston adjustment and pump adjustment. The idle speed screw also 'has' to be backed off for this like the directions say.
I think the float is your whole issue at this point. There is also another way the idle mix screws don't work and that is if you get the carb baseplate spacer in upside down. It has notches that must be on the top side.
In one of your other threads you mention a broken dashpot. Do you mean the sol-vac unit? Sol-Vac If so, it is only usually used for AC and an automatic and can be ignored. Did your idle linkage even have a screw that will hit on it?
One last thing regarding the gas running after a shutdown. Do you have the proper gas filter in it and is is sititng level with the center line to the carb and the top line to the return line? The return line needs to be at the top so on a hot shutdown the vapors released go back tothe tank via the return line rather than vapor lock the gas line by pushing all the gas out.
Then again a really high float level will allow it to dribble gas internally for a while.
Mike
Mike Romain is offline
post #9 of 9 Old 01-17-2010, 06:09 AM
Mike Romain
I have seen that before. The screws get worn springs from overtightening them before adjustment or from rust fatigue. The books all say to seat them 'gently'. Then the spring is weak and the screw just plain falls out and someone has replaced it with another.
That makes it a bit of a bear to adjust the idle mix and not have 3 cylinders running rich or lean. I usually believe the long pointy screw and when I reach the best lean idle mix, I try the short fat one some more to see if it is also affecting the lean stumble at the same number of turns the pointy one does. They are usually within a half turn of each other.
Mike
Need help - carb rebuild luckycheesehead Jeep CJ Forum 21 02-09-2008 09:11 AM
Carb rebuild my73CJ Jeep CJ Forum 4 08-28-2007 02:21 PM
Carb rebuild ? OlllllllO Jeep1 Jeep CJ Forum 2 06-14-2007 10:33 AM
85 CJ 258 carb rebuild lotus Jeep CJ Forum 3 03-25-2006 08:35 PM
Carb Rebuild? Feenix Jeep CJ Forum 2 11-08-2004 12:07 PM
