Help on 84 CJ7 Restore - JeepForum.com
post #1 of 11 Old 05-04-2004, 11:36 AM Thread Starter
Feenix
Post #1 - Yes I am a Noob here and as well as with restoring Jeeps so any help would be very appreciated!
I just aquired an 84 CJ7 with a bad 258 but a good T5, I also have a CJ5 with a good 304 and a bad tranny. My question is: Can I use the T5 with the 304? if so what do you recommend that I will need to do so?
Also is mixing fiberglass and steel body parts a bad thing?
Thanks
Feenix
Feenix is offline
post #2 of 11 Old 05-04-2004, 11:45 AM
holiday76
Thanks
Feenix
what tranny does the 304 have behind it? All Cj trannies from the 80 have the same size input and output shafts so if it is fro the 80's it should work.
You should be able to take the 304, the bellhousing and t-5 that was behind the 258, and it will all bolt together.
there is nothing wrong with mixing glass and metal. YOu might be thinking of mixing aluminum and metal. That sometimes creates a chemical reaction that screws up the aluminum...at least thats what i hear.
'80 CJ7
'83 CJ5
holiday76 is offline
post #3 of 11 Old 05-04-2004, 12:12 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Thanks
Feenix
You might want to look into that before you put the T5 behind your 304. It is the weakest tranny that jeep used in the CJ's. I have it behind my 258 with no problems SO FAR, but most people seem to suggest an upgrade to a stronger transmission. I plan to upgrade mine when it breaks. Try this site for some info:
http://jeeptech.com/trans/t5.html
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #4 of 11 Old 05-04-2004, 02:27 PM
jadams68
jadams68's Avatar
Actually the SR-4 and Peugot trannies were the weakest, but the T-5 ain't far behind... It's basically a T-4 with an overdrive 5th.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #5 of 11 Old 05-05-2004, 09:32 AM
twmattox
Slight correction...
<All Cj trannies from the 80 have the same size input and output shafts>
This is true between the 258 and 304. However, the 151 and 150 used different input shaft size and spline count...
twmattox is offline
post #6 of 11 Old 05-05-2004, 10:51 AM Thread Starter
Feenix
I am not sure what tranny is behind the 304, all I know is that it needs work unlike the T5 I have.
The CJ5 that I am pulling the 304 out of is from either the mid or late 70's. So do you guys think I might have a problem with that configuration.
Feenix is offline
post #7 of 11 Old 05-06-2004, 09:50 PM
Guy Hollister
Got the VIN from both vehicles ?
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #8 of 11 Old 05-11-2004, 10:17 AM
Jnmielcarek
Thanks
Feenix
T-5 is a bad idea for the 304. From experience it will not hold. Search for a T-150 three speed or a T-176 four speed which both were factory matches for the 304. I had one of each and never broke anything. Now I'm running a T-18 behind a 360. T-18 is plenty strong with great ratio span, but takes some research to make work.
Jnmielcarek is offline
post #9 of 11 Old 05-27-2004, 11:31 AM Thread Starter
Feenix
Okay, my new problem has to do with the engine mounts for the 304 to fit in my 84 CJ7 frame. I know MORE makes a heavy duty mount for this, but $230. Anyone know of a cheaper one or have another idea?
Feenix is offline
post #10 of 11 Old 05-28-2004, 12:00 PM
mxg342
mxg342's Avatar
Use the motor mounts from the engine donor jeep.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #11 of 11 Old 05-28-2004, 02:08 PM Thread Starter
Feenix
I was thinking of that but will the mounts out of a 73 CJ5 Frame be the right size to put it in my 84 CJ7?
Feenix is offline
New to me 84 CJ Restore leavundst Jeep CJ Forum 49 05-09-2011 09:20 AM
CJ-8 To restore or not to restore? Bananahands Jeep CJ Forum 12 07-07-2007 09:33 PM
CJ5 Restore jmswarts Jeep CJ Forum 2 01-09-2007 07:47 PM
DJ-5 restore plus some wheelchairman Jeep CJ Forum 0 08-07-2006 08:27 AM
Should I buy and restore this CJ7? TheyStoleMyShoe Jeep CJ Forum 9 10-15-2004 04:00 PM
