Help with 76 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Help with 76
The Ruffstuff Optima Battery Box!The Cure for your Tie Rod Roll!Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 07-13-2013, 07:30 AM   #1
ethanunc
1976 CJ5
Help with 76
I have a 76 cj5 with the 3 speed. Im having trouble veryfing the speedometer cable size. Anyone have any thoughts? Thanks!
ethanunc is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 09:02 AM   #2
CSP
The size? There's only one speedometer cable for that year CJ, so there really isn't any need to verify anything.
CSP is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 02:50 PM   #3
JeffreyCharles
1976 CJ5
And, if you really feel the need to look at it, just crawl under and disconnect the lower end at the transfer case. You'll find it running back along the frame near the exhaust pipe. It just unscrews and you'll see the end of the cable inside the disconnected sleeve.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 04:37 PM   #4
ethanunc
1976 CJ5
I guess what i really meant was the length. I saw a few different lengths.
Unread 07-13-2013, 05:29 PM   #5
JeffreyCharles
1976 CJ5
I *think* the 76 uses a 67" cable. If you get one that's 69 it shouldn't make much difference.
Jeffrey Charles
