help with 4.0 head swap!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > help with 4.0 head swap!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 10-25-2007, 09:51 PM   #1
turbophein
1990 XJ Cherokee
i know, i know, do a search. believe me this will be my first question after 3 weeks of endless nights of reading. i will be doing the 4.0 head swap along with the chevy TBI swap. i have read almost every article and page on these swaps. i feel as if i know "bill usa" from all his helpful threads (thanks by the way) i have gathered almost everything i need accept the head bolt washers, which i need for my 7/16 bolts in the the 4.0 head with 1/2 bolts. everything i read says tap them (not a option) or get the washers from clifford performance. i checked there website and can't find them. now i noticed all the threads that mentioned these washers go a couple years back, did they not work out, were people having problems with them, that they stopped selling them.
my question is what do i use, if they don't sell them. does anyone have pics of them, i have access to a lathe and can make them myself, i mean there just a spacer, maybe a little hi temp silicone in between them.
thanks ahead for any help
p.s. bill can i use the "v8" 1227747 computer, with the wrong numbered ecu's v6 chip from a 1990 chevy 1500 v6. i figured i would just try the wrong ecu first and see what happens, all the conversion parts are off this same truck ($50)
Turbophein
1985 Cherokee Sport I6 Auto
New Style Rusty's 8.5" LA Lift, 37" Boggers, 35" BFG MT's, Jeep 6 lug Dana 44's, hydro ram assist, Front & Rear Disc Brakes TNT Front and Rear Trusses, U-bolt Eliminators, 4.56 gears, Front Detroit Locker, Rear Lincoln Locked, Custom Winch Mount Front Bumper, Custom Rear Bumper, xrc8 8000lb winch, Tom Woods Drive Shaft, AA SYE, Tomken Gas Tank Skid, BushWacker Flares, Custom PVC Snorkel, Steering Box Brace, Flowmaster Exhaust, Optima Red Top, CB w/Firestik Antenna.
1979 CJ7 SOLD!!!
Fiberglass Tub, Dana 30 Front, Amc 20 Rear w/ 1 piece conversion, 3 speed, "LOA" Conversion w/YJ conversion Springs,2" Shackles, Longer Driveshafts, 33" Thornbirds, American Racing Wheels, 10,000 lbs Winch, Holley Carb, electric fan, Heavy duty Custom Front Bumper w/ Winch mount, Custom Rear Bumper, Reese Hitch, Steering Box Brace, Military center console, Front spotlights, Rear Flood Light, 4 Rock Lights (fogs), Waterproofed all connections
http://i102.photobucket.com/albums/m...n/flexshot.jpg[******][/******]
turbophein is offline   Reply With Quote
Unread 10-26-2007, 05:30 AM   #2
supraman1990
1980 CJ5
http://www.cliffordperformance.net/M...gory_Code=J258
These are what your looking for I believe
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline   Reply With Quote
Unread 10-26-2007, 05:43 AM   #3
Fatman
2008 CJ7
Got mine from Summit.
http://www.jeepforum.com/forum/showp...81&postcount=2
http://store.summitracing.com/partde...9&autoview=sku
Fatman is offline   Reply With Quote
Unread 10-26-2007, 06:39 AM   #4
gosupes
Get them from Summit as posted, or from Jegs, other local speed shops might have them. Ask for Ford centering washers. When you get them from Clifford, you get 4 for $20. When you buy them from a speed shop, you get a set of 20 for about $35. Use what you need, sell or give away the rest.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is online now   Reply With Quote
Unread 10-26-2007, 09:01 AM   #5
turbophein
1990 XJ Cherokee
thanks everyone that is exactly what i needed. you guys are the best. wish me some luck on the swap.
Turbophein
1979 CJ7 SOLD!!!
Unread 10-26-2007, 02:22 PM   #6
CJBRENT
Speaking of 4.0 head swap, I have a 4.2 258 with the Howell kit. I would like to put the 4.0 head on my motor before i install it. I heard there is some special part number to use for the 4.0 head? This sounds like a lot of work to put this head on, is it worth it? What do i get out of it? Thank you Brent.
I like to wave to random people, you should try it!
Check out:
http://www.TrophyKartForum.com
http://www.militaryvehicleforum.com/
http://MilitarySurplusLiquidation.com/
CJBRENT is offline   Reply With Quote
Unread 10-26-2007, 02:23 PM   #7
Bubba Ray
Good luck and please post your results. I will be doing the same swap soon.
Bubba Ray is offline   Reply With Quote
Unread 10-26-2007, 03:09 PM   #8
Fatman
2008 CJ7
Brent, take a look at this as well as James site at Busted Jeep.
edit:
sorry forgot the link
http://www.jeepforum.com/forum/f8/add-another-40-hp-your-4-2-6-banger-354885/
Unread 10-26-2007, 04:34 PM   #9
gosupes
I think you mean the casting number. Casting 7120 is the preferred head followed by 0630. The 0630 head does not have the threaded port for the temp sensor but a machine shop can drill and tap it. Not a lot of work, pretty minimal considering the performance gain you get. The hardest part is plugging the coolant ports. Most have used epoxy. I've also seen the passages drilled and tapped and then a countersunk screw was screwed in then decked flat. I had the passages milled for a flat freeze plug. Welding is preferred, but there are other route that can be done for a lot less coin.
BTW, that avatar is funny as hell.
Unread 10-26-2007, 08:01 PM   #10
supraman1990
1980 CJ5
On all the blocks I've ever seen, you don't need to fill the ports, they don't overlap at all.
96% complete.
Unread 10-26-2007, 10:56 PM   #11
turbophein
1990 XJ Cherokee
I am working on a parts list now, i probably won't take many pics, there are just so many good threads with pics now. But i am making a detailed parts list with pricing, i plan on starting the swap monday, go wheeling this weekend before it gets torn down, i know its going to be down for a while. from all the stories i have read on the tbi swap, i am expecting the worst, i have all junkyard parts. i just want it to start and stay running, so i can then deal with tuning and chips. then i will be happy!
Turbophein
1979 CJ7 SOLD!!!
Unread 10-27-2007, 09:35 AM   #12
gosupes
To be honest, I didn't check for overlap but I know they are right on the edge if you are using certain year AMC blocks. IIRC, the DMC blocks have a little more meat in that area. But that being said, better safe than sorry. How pissed would you be to finish a rebuild only to find it leaked? Or how about if it started leaking on some trail in the middle of nowhere? No thanks. Considering it only took about 90 minutes to mill the head and install flat plugs it was well worth it.
Unread 02-09-2008, 07:32 PM   #13
turbophein
1990 XJ Cherokee
just wanted to finish this and say i finished the 4.0 head swap, relatively easy. didn't do the FI though, just sold the jeep, so thats that. but the head made a really big difference, much more power and torque, less stalling. +1 on this swap, if anyone has any ?'s let me know
Turbophein
1979 CJ7 SOLD!!!
Unread 02-10-2008, 12:46 PM   #14
UPJ Wheeler
what push rods and rockers did you use? Ive heard a lot of conflicting information. where the rockers centered on the top of the push rods once it was all back together?
'79 CJ7, rebuilt 258, HEI, T5 World Class, D300 Low max 4:1, Flat Belly, Narrowed D44 w/ true trac & diff gaurd, Widetrack AMC20 w/ superior shafts, Detroit locker & crane diff cover, 4" skyjacker lift, 2" BL, TJ flares, 35" tires, York OBA, YJ tub conversion, 6 pt. cage, F250 front shock towers
4.0 Head and TBI on the way
UPJ Wheeler is offline   Reply With Quote
Unread 02-11-2008, 07:53 AM   #15
CJ Snob
I just completed the same. I used the 258 push rods and the 4.0 rockers. The pinging I had with the Mopar MPI on premium seems to be gone. Haven't tried regular gas yet.
CJ Snob is offline   Reply With Quote
