Help !!!!! - JeepForum.com
post #1 of 6 Old 06-10-2013, 04:48 PM Thread Starter
Justyn77
Help !!!!!
Ok so I have a 77 cj .. My problom is I had a buddy tow it and now my gear shifter is stuck in (N) , it will not go in to gear when I start it I have to hold in the clutch .. I let off the clutch and it seams under stress " bogs down " and dies .. So idk tranny or transfer case ?
Justyn77 is offline
post #2 of 6 Old 06-10-2013, 04:52 PM
skizriz
1978 CJ7
With that information, there is nothing to go on.
How did you tow it? How far?
What trans and transfer case do you have?
What mode did you have them in while towing it?
skizriz is offline
post #3 of 6 Old 06-10-2013, 05:02 PM Thread Starter
Justyn77
Stock 3 speed tranny and stock transfer ... For a 77 cj .. He sayed it tower fine it was towed about 200 miles the transmission wan in (N) .. Not sure about the transfer There was heat and a small anoint of smoke coming from the floorboard .. It shifted it to gear fine till I let it sit overnight
Justyn77 is offline
post #4 of 6 Old 06-10-2013, 05:35 PM
skizriz
1978 CJ7
Some require the transfer case to be in neutral, with the transmission in gear. Some need to have the driveshafts unhooked to be towed.
If done wrong, there will be no lubrication and bearings will burn up.
That's why it's important to know exactly how it was towed.
I'm assuming from your post.
It was flat towed.
In neutral with the transfer case in 2HI.
Driveshaft hooked up.
skizriz is offline
post #5 of 6 Old 06-10-2013, 05:49 PM Thread Starter
Justyn77
Yea he was headed my was latched to the towbar .. It was in 2 hi and tranny in N .... I would figure he would have enough knolage to put them both put of gear
Justyn77 is offline
post #6 of 6 Old 06-10-2013, 05:57 PM
skizriz
1978 CJ7
skizriz is offline
