Help - JeepForum.com
post #1 of 5 Old 02-23-2013, 09:01 PM Thread Starter
cjmachine
Help
I recently bought a 1978 cj7 with 3 speed t150 it has the 304 but second gear won't hold unless you physically hold it in. I would like to get first gear down a little lower but can you guys give me some suggestions like what a t18 swap entails.
cjmachine is offline
post #2 of 5 Old 02-23-2013, 09:13 PM
zillla
1930 VJ
T18 swap entails a shorter bell housing, and a shorter ouput shaft on the T18. I found a bell on fleabay for~ $100 and a shaft at Novaks I believe. You will also need a tranny to Xfer case adapter. The driveline will have to be adjusted for length as well.
Or you could rebuild the tranny you have now.
zillla is offline
post #3 of 5 Old 02-24-2013, 06:32 AM Thread Starter
cjmachine
Is there any way to change gearing in the tremec t150 the first gear is def not low enough
post #4 of 5 Old 02-24-2013, 07:04 AM
roboto65
1976 CJ5
No but you can get a Teralow kit http://www.offroaders.com/directory/...ow-dana-20.htm or http://www.amazon.com/Advance-Adapte.../dp/B000FQ22S2
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #5 of 5 Old 02-24-2013, 06:57 PM
CJ51973
CJ51973's Avatar
A t18 swap and a Teralow will be the same
Money by the time your are done. Driveshafts have to be changed with the t18 so that adds $400-500 right there
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
