Hello there and question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Hello there and question
Engo winches available at www.rockridge4wd.com! Free shippFS: Wranger BRIGHT License Plate LED! Just $3! Great valuePremium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 02-26-2014, 01:54 PM   #1
Flooznie
Hello there, my name is Paul and I'm the proud owner of a rusty 1986 CJ7 jeep. I noticed there is no radiator overflow bottle. Where does it go? What is a great place to find jeep parts? This is a big work in progress as this jeep is very rusty and very well used. Thanks in advance.
Paul
Flooznie is offline   Reply With Quote
Unread 02-26-2014, 02:39 PM   #2
Coiz
1979 CJ7
Hi Paul,
Welcome to the Jeep Forum.
The radiator overflow bottle is mounted on the inside of the drivers side fender right next to the windshield washer fluid bottle. The clean white one as compared to the dull yellow windshield washer bottle on the right in the picture.
Lots of good places to buy Jeep parts but Morris4x4 was always the first place I started looking when I was rebuilding my Jeep.
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 02-26-2014, 03:13 PM   #3
rickscj7boom
welcome to the forum.. like coiz said lots of places around even ebay has stuff..
http://www.quadratec.com/products/51216_03.htm
rickscj7boom is offline   Reply With Quote
Unread 02-26-2014, 03:53 PM   #4
SCSEAJAYSEVEN
1978 CJ7
Any local auto parts store sells a universal radiator overflow tank. They come with the mounting bracket, and hoses to install it. The only shipping charges are your time and gas to go get one. Can usually be purchased for less than $15...
KB4ERT
1978 CJ-7 258 4.2L
1982 DJ-5L 151 2.5L
SCSEAJAYSEVEN is offline   Reply With Quote
Unread 02-26-2014, 07:05 PM   #5
BagusJeep
BagusJeep's Avatar
1981 CJ7
Qadratech
Morris 4x4
Amazon (yes, they do stock some parts)
Any parts store
Junk yard
Classifieds part of this Forum
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
Unread 02-26-2014, 08:21 PM   #6
Flooznie
Ok, I went back to the garage and I can't even find mounting brackets for where this thing even goes. This is what it looks like underneath my hood.
Unread 02-27-2014, 01:24 AM   #7
Coiz
1979 CJ7
The brackets are on the over flow bottle, all you need is 4 holes in the fender. Two of them are shared with the wiper washer bottle.
Here, I found better pictures.
The hose from the radiator goes into the small port next to the cap and should be ran to the bottom of the tank.
Mike
My build thread
Unread 03-05-2014, 01:45 PM   #8
Flooznie
I ordered the overflow bottle but I the hole isn't big enough for me to slip the hose through? Do I need to ream it out? I notice in your picture, you have no hose running from radiator to the coolant reservoir.
Unread 03-05-2014, 04:18 PM   #9
Coiz
1979 CJ7
That was taken right after install and before the hose was ran. Yes, I had to slightly ream out the hole to get the hose in and ran to the bottom of the tank.
Mike
My build thread
Unread 03-05-2014, 04:24 PM   #10
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm not sure when AMC started including an overflow tank on the 258, but I know my '81 has never had one, and I've never needed one.
Just FYI.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 03-05-2014, 04:45 PM   #11
Coiz
1979 CJ7
I believe it was in 1982. Mainly as an EPA tool to keep antifreeze from running out on the ground. Coolant expands and contracts by 7%. With no overflow the level always looks an inch or two low after the engine has cooled off. With the overflow tank it will stay full to the brim.
Mike
My build thread
Unread 03-05-2014, 04:50 PM   #12
lucdog
lucdog's Avatar
1980 CJ5
This^^^
B
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote
Unread 03-05-2014, 05:02 PM   #13
Matt1981CJ7
1981 CJ7
My '82 FSM clearly shows the 258 without an overflow. The V8 shows one, but not the 258.
My coolant stays right at the top of the fins, and I've never had any leakage out of the overflow tube. This applies to both my 258 and 360.
Matt
Unread 03-05-2014, 05:13 PM   #14
VooDoo2
1978 CJ7
My washer bottle is on the other side on the firewall and is factory on the 83. Its RHD so it sits under the brake booster. Battery is above the charcoal canister and the radiator overflow
http://www.quadratec.com/products/55310_0102.htm
VooDoo2 is offline   Reply With Quote
Unread 03-05-2014, 08:22 PM   #15
walkerhoundvm
1981 CJ8
My 81 has one, for reference. Sorry to screw up the paradigm :-/
Custom CJ dash lamps: "Check Engine," "Fog Lights," "Front" & "Rear Locker," "Winch Power" and others:
http://www.jeepforum.com/forum/f128/custom-cj-dash-lamps-lockers-winch-check-engine-fog-lights-1332203/
walkerhoundvm is offline   Reply With Quote
