Quantcast HEI/wiring problem - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > HEI/wiring problem
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 12-19-2007, 12:29 PM   #31
Mr.Crowley
1980 CJ7
pics of both types of ballancers..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Old 12-19-2007, 03:53 PM   #32
ego99
What is the easiest way to keep the crank from turning when trying to loosen the crank center bolt?
ego99 is offline   Reply With Quote
Old 12-19-2007, 04:04 PM   #33
Mr.Crowley
1980 CJ7
put it in gear and chock the tires..
[QUOTE=Me]
:hahaha: yj
Old 12-19-2007, 04:13 PM   #34
ego99
I just tried it again but no dice still just turns the crank. It is in gear with the parking brake applied and a 4x4 behind the rear wheels.
Old 12-19-2007, 04:21 PM   #35
Mr.Crowley
1980 CJ7
you may have to give it a few turns till the drive train catches up..Or if you have a strap wrench have someone hold it..
[QUOTE=Me]
:hahaha: yj
Old 12-19-2007, 04:35 PM   #36
ego99
I am going to go get a strap wrench, Mr Crowley I just sent you a PM
Old 12-19-2007, 08:48 PM   #37
JeepHammer
Running On Empty...
1973 CJ5
I usually use something like 3rd gear when I'm using the clutch to hold the vehicle.
The crank has too much mechanical advantage when it's in 1st or Reverse.
Also, you can jam up the flywheel/flexplate.
there is actually a tool for doing that very thing, but a carefully placed pry bar will work just fine too.
I've seen guys put a bar through the Tcase U joint and let it contact the frame, but I'm not crazy about that one...
Nothing specific, just don't much like the feel of it.
One of those things you can't quite put your finger on!
JeepHammer is offline   Reply With Quote
Old 12-19-2007, 08:57 PM   #38
ego99
Well in the process of trying to get the pulley off I noticed some cracks in my frame near my winch bracket so I have been pulling off my winch, bumper, and grill to get a better look. Man, I don't even solve one problem before I find another. This is off the original subject but what kind of place can you trust to weld a frame? I also have a small rusty area in the rear frame near one of the spring mounts that I need cut out and a new piece of steel welded in. I have seen some of the other members on this site have done it themselves but I lack the skills. Anything to look for or questions to ask when trying to find a place to do this?
Old 12-19-2007, 09:09 PM   #39
Mr.Crowley
1980 CJ7
pmed ya back..maybe post something in the wrenching connection part of the forum for the welding..I forgot about that..
[QUOTE=Me]
:hahaha: yj
Old 12-19-2007, 09:25 PM   #40
ego99
Just read it, thanks. Tomorrow I am going to make some calls and see if I can find a place to get that welded once it's running again. That's it for tonight.
Old 12-20-2007, 05:40 AM   #41
Fatman
2008 CJ7
ego, if you can wait till mid January just bring it up here to Raleigh and I'll be glad to help you with the welding.
Shoot me some pics of the needed repairs.
Fatman is offline   Reply With Quote
Old 12-20-2007, 08:15 PM   #42
ego99
Cool, I may take you and es059021 up on that offer, I will take some pics here shortly.
1986 CJ7, 258, cracked rusty frame, broken balancer, grinds in fifth, 6 inches of play in steering.
Old 12-20-2007, 09:17 PM   #43
ego99
Just got the balancer off, yep, looks like a jackhammer was used to install it. The rubber in the balancer itself looks dry rotted and certainly looks like it has spun a few times.
Old 12-21-2007, 01:11 PM   #44
JeepHammer
Running On Empty...
1973 CJ5
Would you post pictures of that?
There are guys on these forums that SWEAR that can't happen!
I try and have everyone check for it, but I get shouted down lots of times...
Idiots with hammers! You just GOTTA love them!
Kept me in business for a lot of years!
Next time, start at the BEGINNING!!
Actually VERIFY TDC of #1 Piston!
Everything is gravy from there!...
Old 12-21-2007, 01:20 PM   #45
ego99
I'll post some pics after I get home. I am going to autozone after work to order some parts. After reading about how to replace the front seal I saw the manual calls for a timing cover aligning tool. Autozone has no idea what I am talking about. Know where I should look for one? This is all based on the assumption that the timing cover has to be removed to replace the front seal, it does right? Here's to riding my motorcycle in winter rain!
Glock Forum
