Quantcast HEI/wiring problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > HEI/wiring problem
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 12-18-2007, 10:00 AM   #1
ego99
HEI/wiring problem
OK, I just finished using an EZ wire kit to rewire my 86 cj7/stock 258. At the same time I installed an HEI dizzy. Problem is I am cranking away and the engine hasn't kicked over yet(tried all morning). I checked cyl #6 for spark and it was there. I made no changes to the carb so there is fuel ( I can also smell it when cranking). So it appears I have spark, compression, and fuel but it's not running. I am going outside again to make sure ALL cyls are getting spark. In some of my searches on this forum I saw people talking about some sort of lube for the dizzy but my instructions said nothing. Anyone know anything about this?? Thanks in advance.
ego99 is offline   Reply With Quote
Old 12-18-2007, 10:03 AM   #2
ego99
I also tried turning the dizzy slightly either way hoping to find a spot close enough to stock timing to make it start but nada. I am 96% sure that I was TDC on the compression stoke when I installed the dizzy.
Old 12-18-2007, 10:55 AM   #3
fatterman
fatterman's Avatar
if your getting spark then it pretty much has to be the timing is way off
fatterman is offline   Reply With Quote
Old 12-18-2007, 12:53 PM   #4
ego99
It's tried to start a couples times now, it just hasn't started fully. I think I know the general area the dizzy needs to be in but I am killing my batt and starter.
Old 12-18-2007, 01:10 PM   #5
ego99
Well it looks like I tried to start too many times and fried my solenoid.
Old 12-18-2007, 01:54 PM   #6
cottontop
Why don't you check your timing, find top dead center on #1 and go from there it could be off.....
Eric
84 Cj-7 with hard top and hard doors that is regaining life as a jeep again
cottontop is offline   Reply With Quote
Old 12-18-2007, 02:01 PM   #7
dirtbagofva
2010 JK Wrangler
2 things...there are 2 TDC's and a little adjustment on a HEI goes a long way. Another thing, make sure you have a bronze gear not a STEEL one. THe Steel one will eat your camshaft gear. Mine I bought from 4WD and it came with a steel gear and nobody warned me, now I need to rebuild the engine.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 12-18-2007, 03:32 PM   #8
ego99
Crap I never heard that about the steel gear, I am pretty sure the one I bought was steel. Just got a new noid and am reconfirming that the engine was at TDC on compression stroke when I installed it. I already pulled the plugs and my #5 and #3 have zero black residue on them, just gas. The others look like they were the ones that fired when I was turning it over. weird
Old 12-18-2007, 04:40 PM   #9
ego99
Timing problem.....
I just installed a hei dizzy and have been trying to get it to work all day. After some tips from other members I back tracked and checked timing again. After 30 mins with my wife's finger in the cyl #1 spark plug hole I realized a big problem. When i look through the plug hole in cyl number one and the piston is at TDC the TDC marking on the vibration damper is no where near the engine TDC marking... I have never taken a damper off but imagine that there wouldn't be more that one way for it to go on but I guess not. Has anyone ever heard of this before? What is needed to get the damper off?
Old 12-18-2007, 04:46 PM   #10
ego99
OK, after cooling down I see there are three bolts on that damper so there is three possible positions it could be in, apparently whoever put this engine together picked one of the two available wrong ways. My cheap daily driver has turned into a money and time black hole
Old 12-18-2007, 04:51 PM   #11
fatterman
fatterman's Avatar
you are on the exhaust stroke not the compression stroke, rotate your engine some more and you will be at the TDC on the compression stroke.
Old 12-18-2007, 04:56 PM   #12
Mr.Crowley
1980 CJ7
you need to be on the compresion stroke of number 1..The piston can be at tdc on the exhaust stroke that will leed you to beleive the ballancer is on wrong..Its keyed so it cant be..Pull the n.1 plug,take cap off dizzy,put finger on hole..Have wife bump the key so the rotor only goes about 1 inch at a time..When your finger gets poped off the hole your on the compression stroke..Rotate by hand the engine till timing marks line up..it may take a few times to get your timing down of the key bumps,but take notice of where the n.1 plug tower is on the cap ''thats why I say to take it off'' so you can anticipate the compression stroke of n.1 cylinder as the rotor makes its way around to the n.1 spot..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Old 12-18-2007, 05:01 PM   #13
krazyzigzagger
1976 CJ7
Your looking at the bolts that hold the pulley. The dampner is keyed to the crank shaft. Pull the number one plug, put a coat hanger in the hole and rotate the engine to bring the piston to the top. Look at the timing mark, if you don't see it make another revolution. You should see it line up with the timing mark. Install the distributor with the rotor pointing at the number one plug wire. Then check firing order. It should start after this.
krazyzigzagger is offline   Reply With Quote
Old 12-18-2007, 05:29 PM   #14
ego99
OK, my wife and I rotated it a few more times, and the timing mark on the damper does not match up with the timing mark on the engine. They are way off. And whether it is on compression or exhaust(that only make a difference for spark and valves) the piston should be at the top of the cylinder when the mark on the damper and engine align. When the piston is at TDC (looking through the plug hole) the mark on the damper is no where neat the engine mark. What gives?
Old 12-18-2007, 07:20 PM   #15
Mr.Crowley
1980 CJ7
what side of the jeep is the timing tab on?..
If it was a rubber lined ballancer like a chevy,I would say the ballancer spun on the snout..Woodruff keys do break..though unlikely they do..
If you line up the timing mark where the piston in the cylinder?..
[QUOTE=Me]
:hahaha: yj
Glock Forum
