HEI Wiring - JeepForum.com
post #1 of 9 Old 01-07-2012, 06:19 PM Thread Starter
cjbert
1983 CJ7
HEI Wiring
83 CJ7, 258. Fresh rebuild just completed and did the cam break in today. I installed a D.U.I. distributor during the rebuild and wired it using the factory red wire with white stripe to the coil to close a relay and draw power for the distributor directly from the battery. Problem is when I shut off the ignition the engine keeps running. I have to interrupt the the relay energize path to shut get it to quit running. Did I screw up the wiring or is it just a junk relay?
cjbert is offline
post #2 of 9 Old 01-07-2012, 06:38 PM
gpower77
Terminal 30 should be the fused power wire coming from the battery.
Terminal 87 should be going to the distributor.
Terminal 85 should be the red wire that was the ignition wire originally.
Terminal 86 should be the ground wire.
I had mine wired that way. Decided to not use the relay as the DUI only pulled 1.5 amps at idle and 2.7 amps at high rpm under load. The original wire is a 14 AWG, I just took out the resistor part of the wire and it works good. 14AWG will handle up to 15 amps. There was not more than .3 volt drop across the wire, so there is no loss in volts/amps.
Lots of people use the relay, which is fine. I just chose not to.
gpower77 is offline
post #3 of 9 Old 01-07-2012, 07:02 PM Thread Starter
cjbert
1983 CJ7
About where in the wire is the resistor located?
Thanks
cjbert is offline
post #4 of 9 Old 01-07-2012, 07:13 PM
gpower77
It is right after the firewall connector, and is about 2-3 foot long, its a resistor wire. It would be the wire that originally went to the coil. Look through your loom, and you will see the writing on the wire, kinda pinkish red as I recall and it will say resistor wire on it.
gpower77 is offline
post #5 of 9 Old 01-08-2012, 10:17 AM
waterdowg
It should run to the plug for the old ICM. It the plug with the red wire and white wire only.
waterdowg is offline
post #6 of 9 Old 01-08-2012, 11:19 AM
JeepHammer
Running On Empty...
1973 CJ5
You need a $1.50 diode in the 'Excite' wire to the alternator.
Radio Shack p/n 276-1143 if I remember correctly, stripe on diode faces alternator.
The 'Excite' wire is the smaller of the two wires in the two wire plug,
Usually brown or black, and usually "Stiff".
Alternator 'Excite' wire feeds off the Ignition circuit you are using to power up your relay,
When the resistor wire ('Stiff', solid wire at the alternator plug) isn't enough to choke off the positive current your alternator makes/supplies when charging,
The relays stays 'Activated'.
The diode is a 'One Way Valve' for electricity, it allows the alternator to get 'Excite' charge, but keeps the alternator from back feeding the ignition system.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 9 Old 01-08-2012, 01:00 PM Thread Starter
cjbert
1983 CJ7
Thanks for the replies. I stripped out the resistor wire this morning and replaced it. Went ahead and removed some of the other useless wires while I was at it. Man that plastic wire loom sure is brittle after 29 years.
cjbert is offline
post #8 of 9 Old 01-08-2012, 02:10 PM
gpower77
Yeah, mine was brittle as well. I took out the green tach/feedback wire and a couple of others when I did mine. Did you get it running?
GP
gpower77 is offline
post #9 of 9 Old 01-08-2012, 02:15 PM Thread Starter
cjbert
1983 CJ7
Yes I got it running / shutting off as it should now. Next I have to tackle an overheating problem that I suspect may be a reverse rotation water pump and then the carb decided to develop a leak at the accelerator pump so it'll have to come back off the engine and get repaired.
cjbert is offline
Another wiring question; wiring alternator to volt gauge? Jeepguy91 Jeep CJ Forum 3 07-20-2010 04:46 PM
SBC conversion wiring. What Jeep wiring to keep? DT5150 Jeep CJ Forum 14 01-04-2010 04:11 PM
DIY wiring TACAMO Jeep CJ Forum 8 10-22-2009 04:48 PM
wiring 350 in cj5 WIcj5 Jeep CJ Forum 0 10-21-2009 04:34 PM
Need wiring help on YJ Tach to CJ wiring danheit Jeep CJ Forum 4 12-31-2008 07:24 AM
