HEI Vacuum increases idle speed. - JeepForum.com
post #1 of 10 Old 05-20-2016, 03:42 PM Thread Starter
NHcjfan
1977 CJ5
Hello all. I recently upgraded to a motorcraft 2150 after battling fuel leakage for a year in my YF. I decided to order a CRT Performance HEI distributor that I thought would compliment the upgrade. Got it all timed up 6 BTDC, runs great idles great.... until I hook up the vacuum line from the carb to the distributor. It immediately advances the timing and increases the RPM. It has an adjustable vacuum advance so I turned it counterclockwise all the way thinking it would fix the problem. No dice. I'm almost ready to put the Prestolite back in her.
Is my carb creating to much vacuum at idle or issue with the distributor?
Any advice would be appreciated or anyone with a similar set up.
1977 cj5 258 motorcraft 2150.
BTW Jeep runs great cruising down the road. Could I run it just on mechanical advance?
NHcjfan is offline
post #2 of 10 Old 05-20-2016, 04:16 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sounds like you have the vac advance hooked to manifold vacuum.
If so, the increase in timing and RPMs at idle is perfectly normal and desirable.
Matt
Matt1981CJ7 is offline
post #3 of 10 Old 05-20-2016, 04:28 PM Thread Starter
NHcjfan
1977 CJ5
I have it hooked up to ported vac on the carb. so maybe my throttle plates aren't closing all the way?
Maybe I will use manifold vac and adjust idle after I hook the vacuum line back up.
Should have some time to work on it tomorrow. Just looking for a few ideas to get started.
NHcjfan is offline
post #4 of 10 Old 05-20-2016, 04:59 PM
Matt1981CJ7
1981 CJ7
Yes, ported vac at idle indicates the throttle plates are open too far. The idle circuit may be under- jetted.
I prefer manifold vac advance for the stronger, cooler, more efficient idle.
Matt
post #5 of 10 Old 05-20-2016, 05:22 PM Thread Starter
NHcjfan
1977 CJ5
I think I will run it off manifold vac and adjust the idle to spec.
Should I address the other issue? Is there a way to adjust the throttle plates?
I really want to dial this thing in properly. I may have to pull the carb back off to see.
NHcjfan is offline
post #6 of 10 Old 05-20-2016, 05:29 PM
Matt1981CJ7
1981 CJ7
Where did your lean/best idle mixture screw adjustment end up?
Matt
post #7 of 10 Old 05-20-2016, 06:20 PM Thread Starter
NHcjfan
1977 CJ5
About 1 1/4 out. I need to get a vacuum gauge. Just did it by ear.
NHcjfan is offline
post #8 of 10 Old 05-20-2016, 07:09 PM
Matt1981CJ7
1981 CJ7
Yeah, you need a vacuum gauge. Ear-tuning only goes so far.
Matt
post #9 of 10 Old 05-23-2016, 03:48 PM Thread Starter
NHcjfan
1977 CJ5
Thanks for the advice Matt. I simply adjusted the idle after setting the timing and hooking up the vac advance. Silly mistake on my part as I was setting idle first. Anyway Jeep is running better than ever. Just picked up a T18 so now on to that project.
NHcjfan is offline
post #10 of 10 Old 05-23-2016, 04:33 PM
Matt1981CJ7
1981 CJ7
Great to hear!
Good luck with the trams swap.
Matt
