HEI Relay Question - JeepForum.com
post #1 of 20 Old 11-11-2012, 12:15 PM Thread Starter
FamousJerry
2014 JK Wrangler
HEI Relay Question
If by some chance i wired the switched power and ground backwards would that keep the relay from turning off? I can start my jeep but turn off the ignition and its still running .
FamousJerry is offline
post #2 of 20 Old 11-11-2012, 01:11 PM
CSP
No it shouldn't. Either terminal could be for the ground or switched power as it's really just a switch within the relat and there isn't any polarity involved.
CSP is offline
post #3 of 20 Old 11-11-2012, 04:11 PM Thread Starter
FamousJerry
2014 JK Wrangler
Well I wired it as I found on here red with white tracer for the trigger power and it starts fine. Just can't shut it off.
Not sure what I did wrong.
post #4 of 20 Old 11-11-2012, 04:14 PM
skizriz
1978 CJ7
Had that happen when I wired my starter solenoid backwards one time.
skizriz is online now
post #5 of 20 Old 11-11-2012, 04:18 PM
brownbagg
1930 MK Compass
why you got a relay on the hei. just wire it straight from the key? that a question not a insult
brownbagg is offline
post #6 of 20 Old 11-11-2012, 07:43 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I was curious about the relay also. I'm going HEI and want to do it right. I went nuts w/grounding everything. And have a "relay bank". Never thought of using it though.
"Relays are your friend"..someone told me.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #7 of 20 Old 11-12-2012, 07:33 AM
CSP
A relay is used to avoid voltage drop.
CSP is offline
post #8 of 20 Old 11-12-2012, 09:55 AM Thread Starter
FamousJerry
2014 JK Wrangler
its strange that the only thing that really changed it the relay to activate the power and i cant turn it off with the key. I pull the redwire with white tracer and it will turn off. Time to get the test light out and see what the heck i did wrong. But on a side note, runs even smoother than it did before and a bit peppier that before.
post #9 of 20 Old 11-12-2012, 10:46 AM
CSP
You need to check the wire triggering the relay and be sure that it has no power with the key off.
CSP is offline
post #10 of 20 Old 11-13-2012, 08:19 PM
hutch1200
hutch1200's Avatar
1979 CJ7
CSP & skizriz: blank slate, would you use a relay here? Or will I be going overboard? How about inline fuse? It didn't have one stock, but WE all want better, no?
Or just follow the directions. You know, those silly papers that they put in all kinds of boxes of stuff you buy.
post #11 of 20 Old 11-13-2012, 09:30 PM
CJ258
1974 CJ5
I just came off my starter relay. Haven't had a problem.
CJ258 is offline
post #12 of 20 Old 11-13-2012, 11:40 PM
BagusJeep
1981 CJ7
You can come off the starter relay (solenoid) but when AMC did that they used a fusible link. If you are going to power off that connection then it will get good clean battery voltage BUT you should put some harness protection in or you could put the entire battery content through a wire to ground and that is how modified CJs burn to the ground.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #13 of 20 Old 11-14-2012, 06:03 AM
swilliford
1976 CJ5
I had the same problem with my 76' after an HEI upgrade. Any power, no matter how little will keep the relay open. After numerous problems (with the relay I would have to crank the motor 2 or 3 times before starting) I decided to do away with the relay and put in a 30 amp toggle switch. Its not traditional but works a lot better, As soon as I turn the key the motor fires up.
swilliford is offline
post #14 of 20 Old 11-14-2012, 10:28 AM Thread Starter
FamousJerry
2014 JK Wrangler
my motor fires right up, just cant shut it off after driving. And the trigger wire is not hot when the ignition is off, so im more perplexed now.
post #15 of 20 Old 11-14-2012, 10:32 AM
CSP
Perhaps you have a bad relay that has the contacts sticking.
CSP is offline
