HEI module/Stealth HEI will not cooperate - JeepForum.com
post #1 of 5 Old 09-05-2009, 11:42 PM Thread Starter
Olrev
1981 CJ7
Recently upgraded;TeamRush, E-coil, dedicated grounds, and tried the HEI module. I've tried 3 different modules and they all affect my timing negatively. I can put the stock Motorcraft ignition module back in and it runs fine. Has anyone else run into this?
Yes, I hear your...."Just stick the factory ignition dummy!". I guess I can't leave well enough alone. From what I've read, the e-coil tends to fry the stock module.
Any input?
Olrev is offline
post #2 of 5 Old 09-06-2009, 06:27 AM
Mike Romain
'Upgrades' huh.....
If you keep a ballast resistor in the circuit, the ignition module will work fine with a hotter coil, I have been running an Accel SuperCoil for ten years now as my 'only' ignition mode besides killing the computer, all the rest of mine is stock and it runs very well. Accel told me via email to just keep the resistor wire in there, they were right.
I have heard of folks having issues if they don't get the orange and purple pickup wires right, there is a plus and negative side there.
Here is how my stock (no computer, Nuttered) engine runs with 91 octane ESSO gas and the timing set at 8-9 BTDC using the stock carb, OEM cap, rotor and wires (from Jeep Dealership) and an Accel coil with 3.31 gears turning 33's. (while still passing emissions and giving 21 mph highway)
1st lights up the 33's 'way' too easy off a stop. 2nd hauls fast to 52 mph@4400 rpm. 3rd pulls hard to 75 mph. 4th buries the speedometer and I have 'no' urge to find out how fast 5th will go.... It also will crawl up a sand pit wall or ravine wall at 400 rpm without a chug, get too steep and it just churns the tires in...
I mean what more could I ask for out of a poor old 258?
Mike
Mike Romain is offline
post #3 of 5 Old 09-06-2009, 06:36 AM Thread Starter
Olrev
1981 CJ7
Yep, I need to get this figured out and leave it alone. I originally started out with replacing an HEI distributor and decided to do the whole ignition. I think i've narrowed it down to either the resistor wire or a ground issue with the HEI module. If I don't nail it down today, I'm going back with the stock coil and factory ignition module and I'll just keep a spare with me.
Olrev is offline
post #4 of 5 Old 09-06-2009, 06:38 AM
Renegade86
Originally Posted by Mike Romain View Post
'Upgrades' huh.....
Thanks for that info Mr. Romain. Will soon be making the upgrade to HEI myself.
God Bless
1986 Renegade
Renegade86 is offline
post #5 of 5 Old 09-09-2009, 05:00 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Also twist the wires running from the distributor to the module or you could be picking up some extraneous noise impulses causing it to miss-fire.
John Strenk is offline
Pre-Stealth HEI...anyone know if I can buy this part? 83cjnut Jeep CJ Forum 8 10-17-2009 01:48 PM
Stealth HEI ign, I've botched something Olrev Jeep CJ Forum 2 09-09-2009 05:23 AM
Stealth HEI, now no start VACJ7 Jeep CJ Forum 17 07-14-2009 04:18 PM
stealth hei ? dalefan388 Jeep CJ Forum 7 02-12-2009 02:03 PM
Stealth HEI module VACJ7 Jeep CJ Forum 4 01-31-2009 10:54 AM
