HEI Module/E-coil...compatible with factory fusable link? - JeepForum.com
post #1 of 4 Old 09-06-2009, 05:26 AM Thread Starter
Olrev
1981 CJ7
For those of you who have done the HEI module or stealth HEI, have you had problems using the factory fusable link that feeds the coil? I'm using the Ford e-coil and running into problems. I think I've narrowed it down to this.
Have you guys bypassed the link?
Olrev is offline
post #2 of 4 Old 09-06-2009, 05:39 AM
Mike Romain
The 14 ga fuse link wire on that circuit hooks up at the fender solenoid. It blows 'just' before something catches fire (hopefully) so that means you have a dead short in your wiring someplace.
If you bypass the fuse link, make sure you have a couple fire extinguishers handy and the fire department on the speed dial...
I have seen folks use an inline fuse and even a headlight for a temporary connection while they tried to track down the short circuit.
Mike
Mike Romain is offline
post #3 of 4 Old 09-09-2009, 04:03 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Odd. If you really ran it this way you probably cannot shut your engine off. or something else wierd will happen I think. Are you perhaps using a relay inline with the feed from the fuseable link to power the ignition coil?
John Strenk is offline
post #4 of 4 Old 09-09-2009, 06:56 AM
JeepHammer
Running On Empty...
1973 CJ5
There IS NO FUSIBLE LINK FEEDING THE COIL!
There is a resistor wire feeding the coil, and it's not a problem.
The fusible links protect the main alternator wire,
And the main fuse block wire,
NOT THE IGNITION.
The ignition circuit is protected by a 3 to 5 Amp FUSE in the fuse block, not a fusible link.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
Solenoid-Fusable Link burning up sjconrad97 Jeep CJ Forum 3 09-10-2009 10:16 AM
ign module died during e-core coil upgrade CarMead Jeep CJ Forum 4 08-06-2009 09:13 PM
Factory tach with MSD module? chadlow Jeep CJ Forum 8 03-10-2009 06:05 AM
Replaced factory coil with MSD Blaster 2....Jeep won't start!! lxlmongooselxl Jeep CJ Forum 2 06-19-2008 05:41 PM
is the T5 tranny compatible with the 304 V8??? easy_roller Jeep CJ Forum 11 02-15-2006 11:10 AM
