HEI distributor upgrade - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > HEI distributor upgrade
Unread 09-14-2015, 10:32 PM   #1
baconboy89
1974 CJ5
I am wanting to do the hei upgrade but i have read a lot about problems with hardened gears. I have a 74 cj5 with the 258 btw. anyone have any additional insight on this problem? this is the distributor I was considering. http://www.ebay.com/itm/AMC-JEEP-CJ5...097110&vxp=mtr It specifically sas it has a hardened gear. Ive also read that the hardened gear is fine for the 258 because the cam gear is part of the cam. An insight about the hardened gear is greatly appreiciated. Also if this is not a good distributor other reccomendations would be great too. I do have a points type distributor now though so some conversions will not work. Im sure you all know that though
baconboy89 is offline   Reply With Quote Quick reply to this message
Unread 09-14-2015, 10:43 PM   #2
Mortgage-payer
1976 CJ7
The concerns about gear hardness were relevant 5 or 6 years ago. From what I've seen you they seem to have their act together.
Can you take the gear off your existing distributor and install it on the new one? Best of all worlds.
I call it a distributor, not a dizzy.
Mortgage-payer is offline   Reply With Quote Quick reply to this message
Unread 09-14-2015, 10:52 PM   #3
Bgeddes
Bgeddes's Avatar
1978 CJ5
unless the cam has been replaced, the hardened gear might pose a problem
Either reuse yours or get one from a jeep specific source. The HEI can come from any Chevy straight 6.
The HEI is a really nice upgrade for your 4.2
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline   Reply With Quote Quick reply to this message
Unread 09-14-2015, 10:53 PM   #4
baconboy89
1974 CJ5
I have not ordered the distributor yet so i don't know if the gears will swap over. The description of the distributor specifically calls it a hardened gear but it also says itit's oe spec so should I not worry?
Unread 09-14-2015, 10:58 PM   #5
baconboy89
1974 CJ5
I do not think the cam has been replaced. Do you know of a source that I could get a high quality gear from?
Unread 09-15-2015, 09:25 AM   #6
JeepHammer
Running On Empty...
1973 CJ5
Depending on budget, for about $300 you can get a DUI,
Davis Unified Ignition,
And they normally don't kill engines.
JeepHammer is offline   Reply With Quote Quick reply to this message
Unread 09-15-2015, 10:57 AM   #7
hunterstroble
2nd that. I have a DUI distributor. You get what you pay for.
hunterstroble is offline   Reply With Quote Quick reply to this message
Unread 09-15-2015, 11:20 AM   #8
swatson454
1983 CJ7
And their customer service is some of the best I've ever seen.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2015, 06:24 PM   #9
AeroMoto73
1973 CJ5
I've got one that I took off after I upgraded to TBI and computer controlled ignition. Only had it on for a year. Too bad it's for a V8 or I'd make you a nice deal.
AeroMoto73 is offline   Reply With Quote Quick reply to this message
Unread 09-15-2015, 07:03 PM   #10
CSP
Your '74 has a Delco points distributor (if stock still) and the gear will swap over to an HEI.
CSP is online now   Reply With Quote Quick reply to this message
Unread 09-15-2015, 08:19 PM   #11
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I took the plunge and put a DUI HEI with a quality set of spark plug wires on my 258 and it made a noticeable improvement, especially getting on the freeway when accelerating from 40 to 60 MPH. I have said this so many times here that I'm sure some people are tired of reading it. Then, drop on the Weber 38 and my 258 was *really* lively at all speeds. These are two upgrades well worth the time and money.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline   Reply With Quote Quick reply to this message
Unread 09-17-2015, 11:38 PM   #12
baconboy89
1974 CJ5
So I could get a GM hei and the gear would just swap over? if i did that would i need to adjust the advance curve? That seems quite complicated.
Unread 09-18-2015, 09:08 AM   #13
CSP
Yes you could since you have the straight six engine. That's exactly what's in mine. You do not have to adjust the timing curve. It wouldn't hurt, but it's far from necessary.
Any '75-80 GM HEI from a straight six is the distributor you want. IIRC, the '75 has a remotely mounted coil and the rest of the years have it in the cap.
Unread 09-19-2015, 07:00 AM   #14
CurtG
CurtG's Avatar
Weber 38 and a DUI here also...great pair!
CurtG is offline   Reply With Quote Quick reply to this message
Unread 09-19-2015, 12:41 PM   #15
baconboy89
1974 CJ5
I'm lookimg at one on ebay, the guy says he buys them for the gm I6 with no gear and then puts the AMC gear on them. (Its the same guy that sells the Motorcraft carbs for jeeps)
