HEI Distributor - JeepForum.com
post #1 of 7 Old 03-02-2008, 09:58 AM Thread Starter
kjhibbs
1981 CJ8
HEI Distributor
I have a 1980 CJ7 with the 258 carbureted engine. I was wondering if anyone has run an HEI distributor on a setup similar to this, and what the results were? I was also curious as to the California smog legality of such a move. If anyone has any info that would great!
kjhibbs is offline
post #2 of 7 Old 03-02-2008, 04:18 PM
h2oman
yup..
All 3 of my Cj's are running with the HEI setup currently. My 79 with the 258 is using a DUI unit (brand of HEI), but my others with the junkyard swap HEI performed just as well.
Sorry but I don't know anything about Cali. smog regulations, we don't have to worry about that here in Michigan.
Good luck.
1957 willys wagon----shhhh, you can hear it rusting....
1969 POWER WAGON-318, 36" tires, 60 rear w/ lock, D40 front, 4 spd manual trans., 4.10 gears
1976 CJ 7, 360, auto w/ quadratrac
1978 cj-5-mated to a 94 wrangler in a strange experimen
1979 cj7, best $5000 jeep that $13,000 can buy
2006 POWER WAGON-'nuff said.'
h2oman is offline
post #3 of 7 Old 03-02-2008, 04:30 PM
frank c
1981 CJ5
I have a question for you, isnt there a cutoff year for conforming to smog tests in calif.? you mean to tell me that a 28 year old vehicle isnt exemt?
frank c is offline
post #4 of 7 Old 03-02-2008, 06:07 PM
CJ Chet
I have an HEI on mine (Performance Distributors DUI) and I love it, however it would never make inspection in Ca.!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #5 of 7 Old 03-02-2008, 08:47 PM Thread Starter
kjhibbs
1981 CJ8
Sadly the cutoff is 1975. They may up that date in the future, but all of the talks I here right now are that they want to drop it...
As to the junkyard sway, what rig do you find the HEI in that will fit this model?
kjhibbs is offline
post #6 of 7 Old 03-03-2008, 07:58 AM
frank c
1981 CJ5
I have an 81 and from all the research I've done my butt says, I mean in my opinion, you'd be better off with the team rush upgrade, from researching it looks like it is superior in many ways to the GM swap. I've been a SB Chevy guy for a long time.
Just before movin to AZ. I sold a 34 ford tudor I built from the ground up starting with a 64 327 I build up on an engine stand then shoped around for a chassis to put it in, ended up with a brand new 34 repop chassis mustang II ford 8" rear TH350 etc. etc. etc. Hand made solid brass dashboard inserts. and a whole lotta other work.
Any way if you research it you might find the conversion on the stock dist. system will be your best bet for many reasons.
Check this out and don't forget to "HAVE FUN" while doin it.
http://www.junkyardgenius.com/ignition/ign01.html
frank c is offline
post #7 of 7 Old 03-03-2008, 08:31 AM
flashawk
flashawk's Avatar
1979 CJ5
I don't know about El Dorado county, but here in Tuolumne county we only smog when the vehicle is sold (you should get a P.O. box down here..). An HEI setup is legal in California, it allows for a hotter spark thus more complete combustion thus less emissions. I have an HEI on my V8 with 60,000 miles on it and no gear problems (after inspection) or any problems for that matter. It is a subject of much debate around here.
1979 CJ5 360 V8 w/Holley 470 Truck Avenger, HEI Ignition, Livewires w/E3 Sparkplugs, Hedman Hedders, Flowmasters, DANA 30 w/Auzzie Locker, AMC 20 limited slip "N" 3:54's, Tuff Country 2.5" lift, Rancho RS5118, Rubicon Express Quick Disconnects, Currie 1/2" lift Heavy Duty Greasable Shackles, DANA 20, T150, Mile Marker PE8000 w/MiFi Controll Box, Bestop Super Top, Warn 6 bolt Premiums, 31x10.50x15
flashawk is offline
Cannot get the Distributor to go all the way in! BG33 Jeep CJ Forum 4 01-02-2010 02:18 PM
304 '75 Prestolite distributor vs 304 '78 distributor Dad03 Jeep CJ Forum 19 08-26-2009 07:50 AM
amc 360-Distributor new or ? 2manytoys2 Jeep CJ Forum 27 03-11-2009 12:59 PM
Distributor came out!!! JeromyCJ7 Jeep CJ Forum 5 03-14-2008 09:59 AM
which distributor? marmaduke Jeep CJ Forum 6 09-08-2006 12:52 PM
