I have material to make my own but the reason everyone doesn't make these themselves must be finding the taps. I need a 11/16"-18 NF right & left hand tap. MSC has the right but the left is not easily found. Keeping in mind that I don't want to spend too much (you can buy a tie rod already made for $90) anyone found a source?
check out http://www.jeepxtremes.com/rods.html. Me and LT1CJ7 are running these. They are bullet proof, and you get 0 bumpsteer from this setup. :thumbsup:
Just a thought about manufacturing these. Are those rods that you purchase threaded all the way through? If so, then just run your tap all the way through the rod and you will end up with right hand thread on one side and left on the other, no?
You would have corkscrewed all the way through starting at one end to the other, so if you were right hand thread on the end you started at, would you be left hand at the other end? Not sure if I am screwing this up...
A right hand thread is a right hand thread regardless of which direction you look at it. Think of a common nut. You can run the bolt in from either side. You need two different taps.
Now I know why everybody doesn't make there own tie rods:
11/16-18 NF right hand tap=$12.00
11/16-18 NF left hand tap=$95.00 :drool:
Big Daddy looks good to me.
Why don't you look around to a couple of machine shops. The may have the tap and charge low amounts of labor is the hole is predrilled and everything. They can probably powertap the hole in under 1/2 an hour.
I know it's a PITA but what about just tapping both ends right hand and using a RH rod end? It would make it harder to adjust but you could still do it...
I thought about that. But if I start replacing good tierod ends plus doing the work and still buying the right hand tap and jam nuts am I staying ahead. I loose the fien adjustment also. I can get a Big Daddy set up for $149 or $80 for just the tierod off ebay. Plus it's powder coated :laugh: . Thanks for all the help anyway. I'll concentrate on my high clearance skid. Work begins tomorrow.
I used 1.25 DOM tube and bought the bung threaded inserts. I like you would have preferred to tap the tube but the taps as you know are cost prohibitive. I made my drag link and tie rod about a year ago and have wheeled em hard, no problems yet. Just weld the inserts in the tube and your good to go. This may be the way to go for you being as you already have the tube and ends. Give Shane a call @ http://www.hbrk4x4.com/ for the bung inserts they come left and right hand thread.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
