Quantcast Heater Upgrade Fan Part Number - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Heater Upgrade Fan Part Number
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-21-2009, 01:33 PM   #1
starfire340
1983 CJ7
I know this has been beat to death, but its getting near winter so the GM heater upgrade might be getting some attention again. Just wanted to let anyone interested that the Siemens part number for the short shaft blower motor is the 102 NOT the 105. I just went thru this with my parts guy at the local parts store and verified that the shaft lengths are different. The 105 shaft is the long shaft version. Going to finish up the upgrade this afternoon.
Just wanted to pass this along.
mark
starfire340 is offline   Reply With Quote
Old 11-21-2009, 01:42 PM   #2
ctm
also I have seen the parts packed in the wrong box so you think you are getting the correct one but you are not. Correct shaft length is 1 3/16" , the longer one is 1 13/16". Check before you leave the store.
ctm is offline   Reply With Quote
Old 11-22-2009, 09:55 AM   #3
CJ Chet
I just went to Autozone and told them I need a blower motor for an '86 CJ7, and guess what they show as the replacement?
Siemens PM102.
Beer is the answer - it doesn't matter what the question is!
'86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift.
'04 TJ Sahara.
'00 TJ Sahara.
CJ Chet is offline   Reply With Quote
Old 11-22-2009, 10:14 AM   #4
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Something wrong here gents... The GM Blazer blower motor is Way bigger than a CJ7 blower to the point you have to do bodywork to make it fit. You have to cut the hole bigger.
I can't see how they could call that motor a CJ7 one because it just plain won't fit.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 11-22-2009, 10:21 AM   #5
poppatello
Yes, they do have two parts with the same number. I found out the hard way. Another note though, I have a guy who works on jeeps and sometimes knows what I'm looking for before I tell him. So if I walk into the parts store and tell him I'm looking for a heater blower, I don't even have to ask him half the time. I went to NAPA for the first heater and they gave me the smaller one for the Cj. The fan will not fit as it hits the heater backing plate. You have to get the blower with the longer shaft. You should take your old heater blower with you and line the blower plates up side by side. If the shaft is the same length, it's the wrong one. Something they fail to mention when doing the swap...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline   Reply With Quote
Old 11-22-2009, 10:22 AM   #6
poppatello
Siemens PM102.
That blower does look like the smaller Cj blower. It is not the correct one. When you put the blowers side my side, the upgrade blower will be double the size of the older one...
Paved Roads
Old 11-22-2009, 10:42 AM   #7
Mike Romain
Off Road Forever
Originally Posted by poppatello View Post
Yes, they do have two parts with the same number. I found out the hard way. If the shaft is the same length, it's the wrong one.
Umm backward there I think. The shaft has to 'be' the same length, the long one won't work, the fan hits.
The proper one is 1 3/16" , the longer one is 1 13/16".
Mike
Old 11-22-2009, 11:07 AM   #8
keith460
Jeep. There's Only One
keith460's Avatar
I always thought and bought the fan motor for the Chevy Blazer "without" A/C and it is the correct one. Chevy Blazer motor for A/C applications will have a longer shaft that you do not want. Got it from NAPA.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums/showthread.php?t=434226
keith460 is offline   Reply With Quote
Old 11-22-2009, 11:07 AM   #9
texasimport
1978 CJ5
And yes you get to cut the hole in the fire wall to make that bigger motor fit. Just finished mine this fall here in Colorado and with a soft top we can now not wear coats anymore. Coldest morning this year was around 17. Not tooo bad, warms up in about 10 minutes. My teenager uses this as his daily driver and trust me I would hear it if him and his little brother weren't toatsy for the 35 mi round trip to school and back.
Now I get to swap the motor blower switch from the PO toggle back to a 3 way.
78 304-CJ5
texasimport is offline   Reply With Quote
Old 11-22-2009, 11:29 AM   #10
Mike Romain
Off Road Forever
I have done two of them and am about to do a third in January. I asked for one for a 73 Blazer 350 with AC and both fit. I am up in Canada though...
I used this write up: Jeep Heater Blower Motor Upgrade
Mike
Old 11-22-2009, 11:30 AM   #11
CJ Chet
The long shaft motor in your photo is the Siemens PM105. The PM102 is the proper one. Although Autozone calls out the PM102 as a replacement, you DO still have to trim the hole. When I asked for the Blazer motor I got the long shaft model.
'04 TJ Sahara.
'00 TJ Sahara.
Old 11-22-2009, 11:54 AM   #12
keith460
keith460's Avatar
It's not a long shaft but maybe looks that way in the photo because a nut is screwed on to the end. The shaft is the same length as the OEM fan motor, 1-3/16" length.
Napa p/n 655-1039
1984 CJ-7 Renegade
Old 11-22-2009, 02:04 PM   #13
scottymac62
SEAL Team VI
scottymac62's Avatar
1977 CJ5
The Blazer motors at O'Reilly Auto Parts are the VDO brand blower motors and the correct shaft length for our Jeeps is part # VDO102. I installed one in my heater box when I upgraded my heater unit in my 77 CJ-5. Works great!
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, 575 Flex-A-Lite, FlowKooler, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
scottymac62 is offline   Reply With Quote
Old 11-22-2009, 02:30 PM   #14
kauffballs
Ok so I am a new Jeep guy. please tell me about the upgraded heater.....i have a stock 84 CJ7 will this help my heater that works put out more heat? i assume that is what the point is but not sure.
Thanks
kauffballs is offline   Reply With Quote
Old 11-22-2009, 02:41 PM   #15
Mike Romain
Off Road Forever
Thanks
Yes, that is the point. Heat! The people that designed the Jeep heater must have lived in Florida or they had a really sick sense of humor...
The GM blower motor puts out more on low that the Jeep one puts out on high. With it in, I can defrost 'all' my windows at -25C no problems. My wife and I and our two cats even did a 1200 mile run last winter at -25 to -35C and we didn't need gloves or hats and we had our coats open even.
Apparently there are two motor shaft sizes down in the US for the 73 Blazer 350 with AC. I have always gotten the right one up here in Canada, the one with the shorter shaft of 1 3/16" long.
Mike
Glock Forum
