Heater Upgrade - Page 3 - JeepForum.com
post #31 of 45 Old 12-25-2007, 09:36 PM
jp360cj
1977 CJ7
Thank PhatBasturd....Now the question is whether to switch it to the newer style or get a ccw motor. I've got 2 '78 parts Jeeps and between the two of them I think I've got all the parts to switch the heater over to the newer style. I know it would be a lot easier to just get the ccw motor and that's what I think I want to do, but does the newer style work any better (enough to justify all the work)? If so, I might try to switch it otherwise, I'll just exchange the motor
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #32 of 45 Old 12-26-2007, 08:24 AM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
JP - I'm in the same boat that you are in with the odd ball in-cab blower. I'm considering the Mohave option myself, but will probably go the CCW route. Just hasn't been a priority for me (yet).
PhatBasturd is offline
post #33 of 45 Old 12-28-2007, 10:57 PM
Lupo10
OK all. I got it today. Been a hectic week. It fits perfectly! Napa part 655-1039. No more guessing for anyone who comes across this thread. Tomorrow I'll cut the hole and finish the job (hopefully).
1995 Wrangler stock
1985 CJ-7 with a blown engine.
Lupo10 is offline
post #34 of 45 Old 12-29-2007, 03:42 AM
solitudetree
Instead of the mojave, consider the Heater Craft. It puts out twice the BTU's that the Mojave does.
All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
solitudetree is offline
post #35 of 45 Old 12-29-2007, 12:32 PM
jp360cj
1977 CJ7
I got a ccw and am in the process of installing it. I got the mounting plate drilled out, but when I put the squirrel cage on for the test fit, the shaft is too long (like using the pm105 on firewall side heaters)
The part number is Siemens PM106X (Napa p/n 655-1005). Does any know the p/n for the shorter shaft?
jp360cj is offline
post #36 of 45 Old 12-29-2007, 02:22 PM
jp360cj
1977 CJ7
scratch that last post....I did some measuring and realized I have to have the mounting plate from the heater box in front of the mounting plate for the motor.Just thought it would have looked cleaner the other way
jp360cj is offline
post #37 of 45 Old 12-30-2007, 05:10 AM
solitudetree
So how is it working?
post #38 of 45 Old 01-03-2008, 08:49 AM
Lupo10
The blower works great. Got it in New Years Day. Heat is not as intense but I think I may have some airlock plus everytime you move those heater core hoses around you need to play with them. Or it could be perception on my part. This upgrade is so built up that I may have been expecting a jet blower. But its definitely better and for what I spent worth the time and money.
1995 Wrangler stock
Lupo10 is offline
post #39 of 45 Old 01-03-2008, 09:24 AM
PhatBasturd
1976 CJ7
JP - How did it turn out? Did you use PM106X?
post #40 of 45 Old 01-03-2008, 09:43 AM
jp360cj
1977 CJ7
Yeah, I used the the pm106x, but had to make a 3/8" spacer for the fan to fit. Not sure how it works yet because I had to order a rheostat switch from a local electric motor shop and with the holidays and all, it hasn't gotten here yet. Should be in either this afternoon or tomorrow. I'll let yall know how it is as soon as I get it hooked up.
jp360cj is offline
post #41 of 45 Old 01-03-2008, 08:19 PM
Lupo10
I returned my PM 105 and got the PM 102 which was NAPA part 655-1039
1995 Wrangler stock
Lupo10 is offline
post #42 of 45 Old 01-04-2008, 02:34 PM
wswartzwel
Originally Posted by wswartzwel
I just did mine yesterday...Took about 3 hours
Originally Posted by tomthbomb
Obviously no beer involved here.
???? How long should it take?
wswartzwel is offline
post #43 of 45 Old 01-04-2008, 10:24 PM
jp360cj
1977 CJ7
The switch finally came in today. Installed the switch and discovered the fan was still hitting the back of the heater box. Made a 1/4" spacer to go on top of the 3/8 just to make sure it worked, so 5/8" total (probably could have gotten with 1/2" though) Tight clearance on between the motor and glove box, but it works really well. It moves alot more air than stock. I'll really find out how well it works tomorrow night after I finish swapping in the D44 rear
jp360cj is offline
post #44 of 45 Old 01-06-2008, 06:37 PM
dirtman13
dirtman13's Avatar
2007 CJ7
What an upgrade! Finished mine today. Works awesome. I used the Napa 655-1039
dirtman13 is offline
post #45 of 45 Old 01-11-2008, 02:35 PM
digz
1983 CJ7
I will be doing this upgrade this weekend
digz is offline
how do i upgrade my heater? thich Jeep CJ Forum 4 01-19-2008 11:49 AM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 08:50 AM
'76 CJ5 heater upgrade? fearsomfoe Jeep CJ Forum 4 04-22-2007 04:04 AM
CJ-7 Heater upgrade!!! gumby Jeep CJ Forum 10 09-23-2005 01:40 AM
77 cj 7 Heater upgrade steve1244 Jeep CJ Forum 5 02-24-2004 05:53 AM
