Heater question - JeepForum.com
post #1 of 8 Old 11-24-2013, 01:47 PM Thread Starter
ChrisCarlock
1982 CJ7
Heater question
My heater blows semi warm air, probably 70 degrees but not hot air like it used to. I am currently running a 185 thermostat and all heater controls function perfectly. Would changing to a different thermostat help?
ChrisCarlock is offline
post #2 of 8 Old 11-24-2013, 01:59 PM
walkerhoundvm
1981 CJ8
Potentially - technically you should be running a 195* t-stat. Another possibility is that your heater core is buggered.
walkerhoundvm is offline
post #3 of 8 Old 11-24-2013, 02:07 PM
GlennLever
GlennLever's Avatar
185 should give you plenty of heat out of the ducts, I would suspect stuff blocking the heater core (leaves, mud, etc), or the air mix flapper in the heater box is not blocking all the cold air and forcing it all through the heater core, or the heat core is not getting enough flow of coolant through it.
One way to check that you are getting full flow of coolant through the heater core is to make sure both the hoses at the firewall for the heater core are hot.
If you have to pull the heater box the fan motor upgrade is WORTH the effort! Do a search lots of threads on this
try these
http://www.jeepforum.com/forum/f8/cj...l#post13523652
http://www.jeepforum.com/forum/f8/he...wheel-1435600/
http://www.jeepforum.com/forum/f8/he...72/index2.html
http://www.jeepforum.com/forum/f8/he...-heavy-975999/
http://www.jeepforum.com/forum/f8/he...-motor-293665/
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #4 of 8 Old 11-24-2013, 02:09 PM Thread Starter
ChrisCarlock
1982 CJ7
If it helps both if my heater hoses are slightly warm and the same amount on both, just not hot. I'm thinking its the TStat
post #5 of 8 Old 11-24-2013, 02:11 PM Thread Starter
ChrisCarlock
1982 CJ7
My blower motor is out of a Chevy blazer, it's huge
post #6 of 8 Old 11-24-2013, 02:11 PM Thread Starter
ChrisCarlock
1982 CJ7
I honestly might think I accidentally put a 170 tstat in.
post #7 of 8 Old 11-24-2013, 02:18 PM
GlennLever
GlennLever's Avatar
Even 170 should be hot to the touch (hoses) I suspect you are not getting good flow through the heater core, easy way to check, disconnect the hose from the rear of the block at the heater core, direct the hose out the bottom of the engine compartment and start the jeep, coolant should come out like gang busters. connect it back up and disconnect the other hose the coolant should come out of the heater core at the same rate, if not the core is plugged.
Glenn R. Lever
My Web Site
post #8 of 8 Old 11-24-2013, 03:19 PM Thread Starter
ChrisCarlock
1982 CJ7
Shake and Bake! Coolant spewed out of one side of the heater core but not a drop on the other side. I'm assuming the garden hose trick from here.
