Heater not working?? - JeepForum.com
post #1 of 11 Old 11-01-2010, 05:13 AM Thread Starter
supersport126
Ok, so my heater just stoped all the sudden and the volt meter is sitting on zero? Its NOT the motor, thats new. Its not the connection @ the motor I checked that. I think maybe it could be in the ignition? When I turn the key one click the volt meter is not reading anything- this happened same time motor died. All other acceseries work, ie. wipers, lights. Any ideas on what to look for today would be great, Thanks.
supersport126 is offline
post #2 of 11 Old 11-01-2010, 05:58 AM
CrazyHorse6
1979 CJ7
I'm sure you checked it, but just in case - did you check the fuse? There should be a relay as well but my haynes manual is lent out at the moment
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #3 of 11 Old 11-01-2010, 06:16 AM Thread Starter
supersport126
Ah, relay sounds like a possibility. I'll try a new one when I get home.
post #4 of 11 Old 11-01-2010, 03:36 PM Thread Starter
supersport126
Got it, it was the fuse, well kinda. corrosion on / inside fuse block. Thanks Crazyhorse6
So what I learned was the volt meter is fed by the heater circut. It has nothing to do with dash lights or wipers, ect.
post #5 of 11 Old 11-01-2010, 04:23 PM
RedlegBrian
1983 CJ7
Here's a picture of my heater setup:
http://img.diytrade.com/cdimg/548617...own_Jacket.jpg
RedlegBrian is offline
post #6 of 11 Old 11-01-2010, 04:51 PM
CrazyHorse6
1979 CJ7
Glad you got it!
post #7 of 11 Old 11-01-2010, 06:44 PM Thread Starter
supersport126
post #8 of 11 Old 08-26-2013, 08:32 AM
CJ7ROB
I'm having the same exact problem, both were working the other day but they aren't now. Checked the fuse and its good..new blower motor in there but original voltmeter guage. Anything else it could be? -Relay, where is the relay for the heater located? Is there anything else that runs off the heater fan motor fuse besides the voltmeter? Thanks
CJ7ROB is offline
post #9 of 11 Old 08-26-2013, 08:46 AM
WindKnot
1977 CJ7
Maybe I misunderstood. I'll point out the obvious that you shouldn't have voltage after turning the ignition one click. That just unlocks the steering column. Do you mean two clicks to "on"?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #10 of 11 Old 08-26-2013, 08:51 AM
CJ7ROB
My voltmeter worked a couple days ago with 2 clicks to on.
CJ7ROB is offline
post #11 of 11 Old 08-26-2013, 12:44 PM Thread Starter
supersport126
I would say relay or the switch itself went bad. I don't recall exactly but the relay should be under the dash/drivers side?
1983 Cj-7 Heater blower Not working mustanggaragepa Jeep CJ Forum 12 09-05-2010 10:37 PM
need help gas gauge not working and timp not working jarrodblake Jeep CJ Forum 12 05-14-2010 09:10 PM
Heater stopped working, out of ideas attworth Jeep CJ Forum 13 02-04-2010 09:45 AM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 08:50 AM
Heater is not working, need help! lpmorgan Jeep CJ Forum 12 11-03-2007 02:59 PM
