Heater knobs operation - JeepForum.com
post #1 of 5 Old 08-12-2014, 06:50 AM Thread Starter
thewolff
Question,
I worked on my 86 CJ7 heater system last night.
The Air knob;
I pull half way out to "Heat" and I hear something operating but I don't see anything moving. ???
I pull all the way out to "Vent" and the door in the well between the hood and the windshield opens at the same time the door near the passengers feet open. ???
Can someone please explain the operation of this and does the "Temp" knob operate a flow control valve that allows water to flow through the heater core?
Thanks
thewolff is offline
post #2 of 5 Old 08-12-2014, 07:08 AM
Mike Romain
Half way let's outside air into the heater box so you have air flow to the feet or windshield as you move and gives the fan air flow so it can blow properly. This also helps keep a soft top inflated so it doesn't flap so much.
All the way out is the fresh air vent that opens by the passenger side feet and another flap up under for the drivers side feet. This bypasses the heater core area.
The heater control is a bypass flap. Coolant always flows through the core, the heat control just says how much fresh air either goes through the core or bypasses it to just blow outside air in when the air knob is half way.
Mike
Mike Romain is offline
post #3 of 5 Old 08-12-2014, 10:33 AM
Renegade82
1982 CJ7
This may help you.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 5 Old 08-12-2014, 02:48 PM Thread Starter
thewolff
Helps a lot. Thanks guys.
thewolff is offline
post #5 of 5 Old 09-29-2014, 08:13 PM
archer1965
1972 CJ5
Anybody have photos of a 72-75 heater box? Having issues with mine and would like to compare.
thanks
archer1965 is offline
