heater hose routing - JeepForum.com
post #1 of 5 Old 12-05-2011, 09:23 PM Thread Starter
HawkMD
heater hose routing
I recently purchased a 1981 cj-7 with the inline 6 that the previous owner had bypassed the heater core as it was leaking. I was able to install the new heater core but have been unable to find a description or picture of the routing of the heater hoses. Thanks for any help
HawkMD is offline
post #2 of 5 Old 12-05-2011, 09:52 PM
only in a jeep cj
Three hoses total. Top of heater core out to back left of intake manifold. Front of intake manifold over to the thermostat housing. Water pump over to the lower heater core.
Pictures may help even better.....without the rest of the Jeep to be in the way of the view
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 5 Old 12-05-2011, 09:59 PM Thread Starter
HawkMD
Thanks a lot. Heat will be a good thing here in Kansas now!
HawkMD is offline
post #4 of 5 Old 01-07-2012, 11:33 AM
KJNewbs
1983 CJ7
I know, old thread,...but:
I just got done hooking up the hoses as described after installing a new heater core. Before attempting to run the engine form the first time since taking it all apart, is there anything special I need to do? I thought I read somewhere that I needed to burp/bleed the coolant system before running.
Thanks all....
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline
post #5 of 5 Old 01-07-2012, 03:40 PM
CrazyHorse6
1979 CJ7
Yup - check your other post....
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
heater hose routing 31matthew Jeep CJ Forum 2 01-05-2011 04:15 AM
Heater hose routing on built AMC V8 Waltallshy Jeep CJ Forum 1 03-10-2009 09:59 PM
Heater Hose Routing, AMC 360 sevenlitre2002 Jeep CJ Forum 3 02-03-2009 08:35 PM
heater hose routing!? kirkhbauer Jeep CJ Forum 1 11-15-2008 08:34 PM
304 heater hose routing Soundman1 Jeep CJ Forum 1 07-26-2008 12:40 AM
