Heater Craft 28,000BTU upgrade - JeepForum.com
post #1 of 11 Old 11-27-2011, 09:34 PM Thread Starter
mytjtoy
CJ--my drug of choice!
mytjtoy's Avatar
1976 CJ7
I want to go to the Heater Craft 28,000 BTU htr but I have a few concerns which are:
Can it be done on a 76 CJ7 (has anybody done it here--pics maybe?)
Can you control the heat temperature
Do you see almost the entire heater/hoses etc. under the dash
Can you rig it up to still use the dash knobs to control where the air goes
Do those fluid lines end up too close to the passengers feet/legs
Has anybody done this on a full soft tops and in a cold climate state (results?)
Or can you do the Blazer upgrade on a 76 CJ7?
mytjtoy is offline
post #2 of 11 Old 11-27-2011, 10:31 PM
lucdog
1980 CJ5
the answer to the blazer motor ? NO
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 11 Old 11-28-2011, 07:34 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I ran the Heater Craft heater in my old 71 CJ5 when I first built it. The system is a stand alone.. replacing the entire factory heater box. It's fairly compact and tucked up under the dash pretty nice. The inlet/outlet lines came in close to where the factory stuff was. The fan system is built in and uses 3 speeds. I don't recall how I controlled the actual temp but I think it was a pull knob. The heater had 2 outlets and a bunch of soft hose (about 3" diameter) to route it where you want. I ran one hose up to a modified defroster duct and the other hose I split in half (using a plastic plumbing "T" and ran that to either side of the dash.
Coldest weather the Jeep experienced (in Virginia) was probably low 20s.. and it kept the Jeep very warm (with a good sealing top). Matter of fact, I could only stand to keep the heater on low as Medium/High would cook me.
BESRK is offline
post #4 of 11 Old 11-28-2011, 11:47 AM Thread Starter
mytjtoy
mytjtoy's Avatar
1976 CJ7
Thanks for the info. I think with Michigan being near 0 degrees for a month (or can be) this is a must with a soft top and soft doors.
mytjtoy is offline
post #5 of 11 Old 11-28-2011, 02:56 PM
Chewtoy
1976 CJ5
well don't know about a 7 but it works on my '76 CJ5 just fine
Can't control the heat temp, but you can control the cabin temp with fan speed.
Not if you tuck it up nice and neat.
The only dash knob have left is the fresh air one. I took the rest of the heater box out to make room. But "can" is a vague word on this forum. Where there is a will, there is a way.
No, they don't have to.
We are not as cold as you are most of the time, but I have driven it in the low 20s and usualy have to turn the fan down a notch or two.
Sadly no. The 76 is a bastard step child of the Jeep family when it comes to heater and fuel filler.
I can take some pics tonight when I get home for you.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #6 of 11 Old 11-28-2011, 05:14 PM
Oxmarqt
1977 CJ7
Ooo, Ooo! Take lots of pics from many angles if you can. I am planning the same thing and as they say...A pic is worth a thousand words!!
Thanks
Paul
Oxmarqt is offline
post #7 of 11 Old 11-29-2011, 07:03 AM Thread Starter
mytjtoy
mytjtoy's Avatar
1976 CJ7
Thanks
Paul
AGREED, thanks all! We are supposed to get up to 8 inches tonight. Thank God for pole barns for Jeep work.
mytjtoy is offline
post #8 of 11 Old 11-29-2011, 01:57 PM
cj7moneypit
I have been driving my CJ7 for going on 3 Michigan winters now with a soft top, soft doors and the same heater you are planning on. I have found that having defrost is way more important. You can always put on another jacket. When your windshield turns to ice on the inside and all you are looking through is a hand print, the drive is a bit scarier. I installed mine behind the glove box with the entire old heater removed. I'll admit, when the old heater worked, it was allot better than the Heatercraft. It comes with a selector switch that gives the blower a low, med, high setting. The cab doesn’t get hot but does manage to get comfortable. I used the older style defrost duct that has the round end. It works well. Is your original heater working? I still have the old parts. Send me a PM if your interested and in the area. I can get some pictures of the new heater as well when I get home.
84 CJ7 DD, Fiberglass Tub, 258 with MC2100, Nuttered and Rushed.
79 CJ7 Project, 258 Quadratrac
USS Midway, NAS Cubi Pt. PI, NAS Agana Guam, NAS Miramar, NAS Alameda
cj7moneypit is offline
post #9 of 11 Old 11-29-2011, 04:12 PM Thread Starter
mytjtoy
mytjtoy's Avatar
1976 CJ7
You not too far from me at all. 30 minutes. Enjoy the storm tonight. My heater works but I can blow hotter air than it does. I have no defrost and instead of tearing it all apart I figured I am dumping enough money into this thing I might as well do it right. Are you saying the 28,000 btu heater doesn;t blast you out of there? I might end up getting a hard top for the winter next year or just move to the Bahama's. I think a gas fireplace in the back instead of the rear seat would be great!
mytjtoy is offline
post #10 of 11 Old 12-01-2011, 04:46 PM
magilla
magilla's Avatar
1969 C101
It works
Bunch of Jeepster Commando guys and CJ6 guys have swapped, with exceptional results. I just bought one for my Jeepster, as I have a bad fan and a leaking heater core, and this will fix both problems and allow me to put my heater switch in the center of the dash.
One key, no matter whether you do the heatercraft heater or put in a Blazer motor is to make sure you have HOT coolant going to your heater core.
You need to check:
1) Heater core should be unrestricted - a gunked up core = NO HEAT
2) Hoses should be supple, yet firm (and not kink from water pump suction/pressure)
3) ENSURE you have a good thermostat (195 recommended - you'll get better gas mileage to boot) FYI - your thermostat can also be faulty by opening too soon...
4) Obstruction to your radiator (in winter) to allow coolant to heat up.
Here are some links to websites that show installs: One CJ6, one Jeepster:
http://boyink.com/cj6/heater-install...t-heatercraft/
http://jeepstercommandoclub.com/foru...+heater#p87858
Recommend the Summit heater, as it is cheaper ($144 vs. $300 from Heatercraft) and when it arrives, it says "Heatercraft" on it. You can also order defrost hose kit and vent kits with "Y" adapters if you need to.
1969 Jeepster Commando w/Buick 231. T14/D20. D30/D44, 4.10 Locked/Spooled. 4x disc brakes, Saginaw PS. 32" x 9.5" Super Swampers.
1970 Jeepster Commando, in pieces. Buick 350 / SM 465 / D20.
magilla is offline
post #11 of 11 Old 12-01-2011, 06:02 PM
Chewtoy
1976 CJ5
Pictures as promised. They are kind of up close but whacha gona do with an iPhone... kwim? Let me know if there is a particular shot you want.
Tucked up under the dash on the passenger side.
Little to the left so you can see where the hoses go.
Right side mounting. Note the radio antena comming through the sidewall for position reference.
Left side mounting, you can see where the original heater hoses attach.
Hoses comming out the top, they are a little cramped, but not enough to make any difference.
One of the hoses, goes to defrost. You can see just to the right of it (in the pic) the fresh air inlet is still in place so I can open the vent, or not. Use it to adjust cabin temp sometimes. I also had to make my own little "harness" out of zip ties for the defrost because all the stock defrost pieces are bigger than the hose, so I put the hose inside with zip tie harness and viola.
Second hose goes to the little airbox / plenum / vents that came with it when I bought it from 4WheelParts a couple years ago.
airbox / plenum / vents from the front.
Like I said, let me know if there are any other angles you want.
Chewtoy is offline
3 speed heater switch with 1 prong heater motor upgrade jeep7777 Jeep CJ Forum 4 10-29-2011 12:12 PM
Heater fan upgrade for a 85 CJ jack ason Jeep CJ Forum 21 03-28-2011 07:00 AM
77 CJ Heater Upgrade scottymac62 Jeep CJ Forum 3 11-13-2009 06:53 AM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 09:50 AM
Heater craft heaters...any tips/advice?? imtheant Jeep CJ Forum 3 12-21-2004 05:51 PM
