Heater Core Copper or Aluminum? - JeepForum.com
post #1 of 18 Old 10-28-2009, 04:47 PM Thread Starter
J33P'r
She has her top off!!!
So I need to replace my heater core on my scrambler, and If I do a search I see some that look like they are aluminum, and some that look copper, which is the best and why if you know? I'm not as much concerned about the cost difference as I am getting good heat.
any thoughts?
also any good write ups on removal and installation in a CJ?
Thanks Guys!
J33p'r
"Right tools for the Right Job produce Right Results"
J33P'r is offline
post #2 of 18 Old 10-28-2009, 08:12 PM
-AC-
1977 CJ5
The "hot" rumour is that aluminum transfers more heat more efficiently than does copper, but I have always preferred copper. I guess because I'm from Michigan (Copper Country), copper is WAY less brittle and fragile than aluminum, and I can ALWAYS braze up a copper leak, but TIG welding takes special equipment and practice... Don't get me wrong, for someone who TIG's on a semi-regular basis, it's not that big a deal, and anyway, you wouldn't expect to have to do much repair on a new core for at least a few decades. Also, aluminum is usually cheaper. Still, cuz I'm old, give me copper...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #3 of 18 Old 10-28-2009, 08:42 PM
illinicj
1979 CJ7
Copper as a higher thermal conductivity than aluminum, and therefore transfers heat more efficiently. (all other things equal)
illinicj is offline
post #4 of 18 Old 10-28-2009, 08:50 PM
-AC-
1977 CJ5
Hmmm... were I feeling ambitious and not-so-lazy I would head up-stairs and get out my engineering textbooks and see if I could intelligently refute your point. As it is, I guess I'll say that, as I recall, aluminum is a "more efficient" conductor, while copper has more "preferable" conductive qualities, but I'm not willing to argue the point and would rather concede it. I guess the over-riding point is that whatever the Original Poster buys, it should last for a decade or two...
Moot point?
-AC- is offline
post #5 of 18 Old 10-28-2009, 09:08 PM
Roadymi
1982 CJ7
all I know.......Almost everthing I've ever read about cooling issues say go with Aluminum.
Roadymi is offline
post #6 of 18 Old 10-28-2009, 09:10 PM
73jeep
1973 CJ5
Not true.
Copper has higher the "k" value as aluminum.
copper: 231 Btu/(hrftF)
Alu: 144 Btu/(hrftF)
73jeep is offline
post #7 of 18 Old 10-28-2009, 09:10 PM
illinicj
1979 CJ7
Yeah, you wouldn't want to make your radiator out of copper. Too soft. An aluminum radiator is better than steel for heat transfer, which is why aluminum radiators are preferred. If you are talking about a heater core in the safety of a heater box, then copper is better. Thats probably why Jeep did it that way.
illinicj is offline
post #8 of 18 Old 10-28-2009, 09:28 PM
bentshackle
1983 CJ7
Pretty sure that stock radiators are soldered copper (As are stock ('83 at least) heater cores)
Basically it comes down to this. Copper has higher thermal conductivity but is heavier and more expensive. They are soldered together and when clean do an admirable job of cooling most engines. Aluminum is cheaper, lighter but lacks in the thermal conductivity department therefore aluminum radiators generally have more fins and are thicker to offset the poorer thermal properties of the material.
Either type in good condition will serve you well.
BS
bentshackle is offline
post #9 of 18 Old 10-29-2009, 06:18 AM
jfwireless
1976 CJ7
Radiator and heater elements are really made of Bronze, as the copper has a small amount of tin added to make the alloy harder, but the copper alloy is a better conductor than aluminum. Aluminum is just a cheaper material so the marketing guys are trying to convince everybody an aluminum radiator/heater core is better so they can make a better margin on the sale.
Jim
jfwireless is offline
post #10 of 18 Old 10-30-2009, 10:23 AM Thread Starter
J33P'r
Hey guys sorry for the lack of response on my part, I was away with my unit yesterday...
so it sounds like Copper would be the way to go for a warmer Jeep? yes?
but because of todays industry aliminum is a cheaper alternative...
To what I understood from the thread; Aluminum is always a "cooler metal' so therefore it won't provide as much radiant heat as it is dispersed by the blower...
J33p'r
J33P'r is offline
post #11 of 18 Old 10-30-2009, 11:05 AM
jfwireless
1976 CJ7
For your heater I do not think it will make much of a difference unless you live in the artic circle.
Jim
post #12 of 18 Old 10-30-2009, 11:25 AM Thread Starter
J33P'r
Jim
lol well sometimes I might think it is, but it's just New England
Jim & all
Thanks
J33p'r
J33P'r is offline
post #13 of 18 Old 10-30-2009, 03:59 PM
duffer
1955 CJ3B
Conductivity issues aside, my experience switching from a 4 row brass radiator to a 2 row aluminum, with same dimensions, was a good 15 degree drop with the aluminum-they just cool better. You also lose 15 to 20 lbs. I do not expect to build any more rigs with brass radiators.
duffer is offline
post #14 of 18 Old 10-30-2009, 04:31 PM
jfwireless
1976 CJ7
The radiator does not determine the engine operating temp, the thermostat does.
Jim
post #15 of 18 Old 10-30-2009, 04:34 PM
Mike Romain
Well I switched from a 10 year old 2 core copper alloy kinda crudded up rad to a re-cored copper alloy rad because I snapped it in half and that also dropped mine a good 15 % in the temp gauge just by putting nice clean cores in it.
Aluminum is a pain in my opinion, if steel touches it, it burns a hole through it from electrolysis.
Mike
Mike Romain is offline
Radiator: Aluminum vs Copper?? jaz5833 Jeep CJ Forum 19 05-06-2010 06:17 AM
heater core rmc429 Jeep CJ Forum 8 11-02-2008 09:28 AM
heater core khill8469 Jeep CJ Forum 2 05-23-2008 08:07 PM
81 heater core DZLCJ7 Jeep CJ Forum 1 01-12-2004 05:48 PM
heater core jeepsarecool Jeep CJ Forum 5 01-30-2003 05:37 PM
