Heater Core bypass - can I do it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Heater Core bypass - can I do it?
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-12-2008, 11:16 AM   #1
kharmajavah
So, as I was replacing my ruptured heater hoses, I guess I pulled too hard to get them off and now my heater core is leaking. Not badly, but enough to where I don't want to let it get too bad.
I can replace the core myself, but money is tight this month, so I'm wondering: is it safe to bypass the heater core and run a length of hose directly from the water pump to the port on the intake manifold, bypassing the heater core? Logically, it makes sense to be. But, I'm not as experienced with repair as most of you are.
I would just be bypassing the core for a couple of weeks until the next payday. does bypassing the heater core pose any problem?
kharmajavah is offline   Reply With Quote
Unread 08-12-2008, 11:20 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
No problems doing a bypass except the hoses are different sizes.... If you have a good hose clamp and a nut driver or small socket wrench you might be able to get it tight enough. or use the smaller hose and grease it before trying to slip it over the nipple.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 08-12-2008, 11:22 AM   #3
KBONSIG
What you are saying will work - I have it set up like this now for my tub swap. Runs fine - only downside I see is that if you are overheating for any reason, you can't turn on the heat.
Do yourself a solid and replace the blower moter with the 72' blazer when you replace the core.
2003 TJ RUBICON (CURRENT)
1985 CJ7 I6
2000 TJ I6
1995 YJ 4Cyl
1987 YJ I6
KBONSIG is offline   Reply With Quote
Unread 08-12-2008, 11:24 AM   #4
KBONSIG
Yes - what Mike is saying is 100% true - on the manafold I uses (2) hose clamps to keep it tight -
1985 CJ7 I6
2000 TJ I6
1995 YJ 4Cyl
1987 YJ I6
Unread 08-12-2008, 11:27 AM   #5
VACJ5
mine is completely bypassed (via previous owner) all they did was remove the hoses from the inlet and outlet on the heater core and then clamp them to a 90 degree fitting (degree doesnt really matter) I can snap a picture later if you want...
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it... 3/4 Ton YJ
91 2 door Cherocar... in progress
BeachMetalWorks Custom CNC cut Jeep parts & more
VACJ5 is offline   Reply With Quote
Unread 08-12-2008, 11:27 AM   #6
kharmajavah
Thanks guys!
Any chance you know the hose diameters, and which goes where? Mine were incorrect when I bought it, and they've just held out until this week.
Unread 08-12-2008, 11:28 AM   #7
kharmajavah
Thanks! No need for the picture though, I understand what you mean.
Lots of quick replies today...awesome.
Unread 08-12-2008, 11:29 AM   #8
kharmajavah
I've heard of the motor upgrade, but I read *somewhere* that the part numbers for the Blazer and 4.2 Jeep are now the same...so I guess they started using the same motor for replacement?
Unread 08-12-2008, 11:32 AM   #9
VACJ5
cool man, very glad we could help!
Unread 08-12-2008, 11:33 AM   #10
Mike Romain
Maybe for a 4.2 YJ engine or even the 4.0 engine? I also heard that 'one' parts place was using the same numbers, but don't remember 'which' one.
When in doubt, get the cheaper Blazer blower, the premium one has too long a shaft.
Mike
Unread 01-24-2011, 06:55 PM   #11
4lowherewego
1979 CJ7
Can someone post picture of bypassing heatercore... I got a 360 tho... should be same as 304? Or is it not a smart move?
4lowherewego is offline   Reply With Quote
Unread 01-24-2011, 07:01 PM   #12
brownbagg
1930 MK Compass
you know heater cores are only $40. you could take the old one to a radiator shop and have it fix for about 25 or do it yourself, torch and solder
brownbagg is offline   Reply With Quote
Unread 01-24-2011, 07:18 PM   #13
Andy5150
I broke my heater core in my driveway an hour after [I] got my 360 running. I just connected the hoses together with an adapter, and its been that way for 2 yrs. and 22000 mi. I was celebrating with a few cold ones that my 360 was running great, and in a moment of genious decided that a wheelie was in order. Bad idea; heater core came in second, but the motor runs smooth and cool.
Andy5150 is offline   Reply With Quote
Unread 01-24-2011, 10:06 PM   #14
SonicR1
SonicR1's Avatar
I took the one hose off because they were so long. I was able to run the front hose all the way the the back...
... I guess I'm gonna have to fix that too…….
The TJ
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 33" tires, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears.
1974 CJ5 BUILD THREAD
SonicR1 is offline   Reply With Quote
Unread 01-24-2011, 10:09 PM   #15
nedmoore
nedmoore's Avatar
1982 CJ7
WOW! 457 views for a heater hose bypass!
nedmoore is offline   Reply With Quote
