#1 | |
Heater control knobs
How are the heater control knobs removed from the shaft?
#2 |
There is a small set screw. You will need an allen key to get it out. I am not sure of the size though.
1981 Renegade AMC 304 w/35's 1997 SE 2.5 w/31's 2000 4.0 w/33's 2005 GC 4.7 stock |
#3 |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Mine have a spring clip in behind them that has to be depressed with a mini screwdriver to free them from the shaft. The clip moves to the rear of the jeep for release. There is a little notch on the bottom of the knob where the release is.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#4 |
Hey Mike, are these all different? Mine are just held with the set screw.
#5 |
As far as I've seen the factory ones are the clips and I've seen aftermarket ones that use the set screw.
Like these - http://www.4wd.com/productdetails.aspx?partID=5405
Bill H. - 1984 CJ-7 258 W/ Weber DGV 32-36, T5, Twin Stick Dana 300, Custom SOA, Dana 30/AMC 20 Locked 4.56's, 33" Swamper LTB's, York OBA, Custom bumpers, Homemade Swaybar Disconnects, Nutter Bypass, Team Rush http://www.schohariecountyjeepclub.com |
#6 |
Off Road Forever
All the ones I have seen were spring clips. I have seen set screws in aftermarket stuff.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
