Heater box defroster/floor divert flap - JeepForum.com
post #1 of 16 Old 11-09-2013, 11:22 AM Thread Starter
kchadtho
1983 CJ7
A couple months ago, I pulled the heater box from my '83 CJ7 to replace the fan motor, fix cables, etc. I was inspired by a great post a while back on this forum.
Last night, I gathered all the parts back up and discovered the diverter flap that routes air to floorboard or defroster was no where to be found. Ugh!!!
Any chance someone out there has theirs apart and can provide enough dimensional data so that I can get one fabbed? It is a simple piece except for getting the lever shaft right.
Or maybe someone knows a source that already has the info to fab one??
Many thanks...
kchadtho is offline
post #2 of 16 Old 03-07-2016, 10:12 AM
cJAY904
Sorry to bump up an old thread, but I need the same part. Seems like no one replied KChadtho. Does anyone have a suggestion? I dont have the old one to use as a template to fab up a new one. Lets see if anyone has a suggestion.
I am planning on doing the Blazer upgrade and getting the heater box up and running. Thanks in advance.
cJAY904 is offline
post #3 of 16 Old 03-08-2016, 06:39 AM
cJAY904
How bout this, does anyone know whats it is called so I can try to find it?
I have read this thread (Link )and am getting ready to do the same, but looking for this part..
cJAY904 is offline
post #4 of 16 Old 04-07-2016, 12:31 PM
cJAY904
This is the last time i resurrect this dead thread... Last ditch effort.... Anyone know where I can find the deverter flap? Please and thank you!!
cJAY904 is offline
post #5 of 16 Old 04-07-2016, 02:59 PM
Erik719
1983 CJ7
I have mine apart. I will measure it this weekend for you.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #6 of 16 Old 04-08-2016, 07:53 AM
Agar426
1974 CJ6
Don't think the individual part is available, but the entire air box and associated hoses are available here: http://www.mtscompany.com/airbox.htm
Agar426 is offline
post #7 of 16 Old 04-08-2016, 05:47 PM
lugnut28
lugnut28's Avatar
Which one do you need
lugnut28 is offline
post #8 of 16 Old 04-11-2016, 12:21 PM
cJAY904
I have not seen either of the ones you refer to lugnut28. I need to look to see if I have holes for anything like that. I was under the impression the one I needed was like the one form my above post
cJAY904 is offline
post #9 of 16 Old 04-11-2016, 08:15 PM
only in a jeep cj
The two lugnut28 shows are in the top intake tube
The one needed is in the heater box, above the trans tunnel... The defrost door
If I was home I could give measurements. I have a few boxes apart
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 16 Old 08-15-2016, 12:25 PM
cJAY904
Anyone have any suggestions on where I can get the defrost diverter?
cJAY904 is offline
post #11 of 16 Old 08-15-2016, 06:44 PM
OrangeCJ-5
1978 CJ5
As far as I know, you would have to buy a used heater box assembly to get that door.
OrangeCJ-5 is offline
post #12 of 16 Old 08-15-2016, 07:27 PM
only in a jeep cj
Is yours missing completely or do you at least have the pivot rod? (maybe rusted off) If you do I can give you measurements and angles if you want to bent one from cut metal sheet. I don't have a spare
Ed
1975 CJ-6 1983 CJ-8
post #13 of 16 Old 08-16-2016, 06:57 AM
cJAY904
I do have the Rod. How is it attached to the rod? I doubt it rusted off, as there is no sign of rust on any of the remaining parts.
I think I will make it out of an old license plate.
cJAY904 is offline
post #14 of 16 Old 08-16-2016, 09:10 AM
OrangeCJ-5
1978 CJ5
The rod runs through the door
post #15 of 16 Old 09-27-2016, 01:11 PM
cJAY904
ok, I think I am going to try to 3d print one. If anyone can help with any measurement, angles ect...
cJAY904 is offline
fabricator , heater box
