Heater Blower motor upgrade - JeepForum.com
post #1 of 85 Old 02-18-2007, 07:30 PM Thread Starter
napoleoneight
i remember reading a while back about a heater upgrade that invloves swapping out the blower motor for one out of a 70's blazer. anyone have any experience with this mod?
napoleoneight is offline
post #2 of 85 Old 02-18-2007, 07:35 PM
Rollbar
1984 CJ8
Go here:
http://jeep.off-road.com/jeep/articl...otor%20upgrade
<----Click
<---- Click
Rollbar is offline
post #3 of 85 Old 02-18-2007, 08:21 PM
Shameless Elmer
83 CJ5
1983 CJ5
I did my blower motor upgrade as part of a frame-off job. I drove it for the first time in +2 years yesterday. As I was cleaning up today I came across the old blower motor and the box the new one came in.
I installed a Siemens blower motor. The Siemens part number is PM102. The NAPA part number for the Siemens motor is 455-1039.
It cost me $23.00 for the new motor.
Shameless Elmer is offline
post #4 of 85 Old 02-18-2007, 09:04 PM
Cannonball
1996 CJ5
I did mine too and used one from a '76 blazer with air conditioning. the blower fan was about twice as wide so it moves a lot more air. As long as I had the box out i decided that i never wanter to have to remove the unit to replace a blower motor again so i traced a larger hole on the firewall to allow the blower to pass completely through the fire wall. Used some thigk foam insualtion and duct seal to seal the gap between the firewall and heater box upon reinstallation. Now i can unscrew the motor and replace it from the engine compartment with out having to take the heater box out. So far it has lasted 10 years but If i ever need to take it out it will be easier...........
Cannonball
"It aint bragging if you can do it!"
1996 YJ-5 400 SB Chevy, Proflow EFI, NV4500 Trans with 6.34 low, Dynatrac HP Dana 60 Rear / Dana 44 front and 4:88 gears Featured in Sport & Utility June 1997.
Cannonball is offline
post #5 of 85 Old 02-19-2007, 05:57 AM
jeepmor
jeepmor's Avatar
How much improvement fellas. I might have the head off my jeep soon and figure this would be a good one to do while access is somewhat easier.
regards,
jeepmor
jeepmor is offline
post #6 of 85 Old 02-19-2007, 06:19 AM
schmoken
schmoken's Avatar
MAJOR improvement.
schmoken is offline
post #7 of 85 Old 02-19-2007, 07:41 AM
Cannonball
1996 CJ5
well i went wheeling 3 weeks ago when it was -12 with only a soft top! The windshield even stayed clear with the defrost only 1/2 open
Major!
Cannonball
post #8 of 85 Old 02-19-2007, 10:05 AM
Bromius76
The write up above says it should work for 76-86 cj's, but not some 77's. I have a 1976 CJ7, will this upgrade work for me? It says that if the blower is sticking through the firewall it should. But what am I looking for? Still new to this, so I'm not exactly certain. Does anyone have some photos as examples?
Thanks!!!!
Bromius76 is offline
post #9 of 85 Old 02-19-2007, 04:22 PM
solitudetree
Napoleon,
The chevy blower motor upgrade rocks. I did it on mine over a year and a half ago and it makes a huge difference on the amount of heat and defrost return that you get.
Here are links for writeups with pictures so you, Bromius 76 and others know what to look for.
http://www.jeeptech.com/body/heater.html
http://www.manoian.net/jeep/blower_fan.html
http://www.sierrajeep.com/heater.htm
These should help. I did a write up to include bolt sizes and pictures but my computer played pacman with it.
If you have questions, let me know.
All the Jeeps I've owned
79 CJ5 258 six with a weber (current vehicle) T18/Dana20
81 CJ5 258 six (driven out of Alaska thru Canada in winter with a softtop)
75 Jeep Wagoneer 360V8
79 Jeep Cherokee 258 six
solitudetree is offline
post #10 of 85 Old 02-19-2007, 06:28 PM
Bromius76
Tx, Solitudetree. I don't remember seeing anything under my battery tray at that spot. I assume this means I have the "alternate" style heater and so no upgrade? Or would it be possible if I just tear more parts out from a U-Pull and cut a hole in the firewall?
Ah yes... my computer has eaten many a document.. Wacka wacka wacka..
post #11 of 85 Old 02-20-2007, 02:29 PM Thread Starter
napoleoneight
now im one of the write ups you posted i noticed washers stacked between the motor and the housing to align the "hamster cage" fan correctly, is this common to this swap regardless, or was the motor in that write up a special case?
post #12 of 85 Old 02-25-2007, 12:44 PM
only in a jeep cj
He mistakenly used a PM 105 with the longer shaft. ...instead of the PM102 motor
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #13 of 85 Old 02-25-2007, 02:17 PM
smokencj7
i did the upgrade to my 84 cj and used a motor from a 80 blazer with a 350 eng. works real good you have to cut the hole in the firwall bigger and do a littel mod to the box and that was it
smokencj7 is offline
post #14 of 85 Old 02-25-2007, 05:01 PM Thread Starter
napoleoneight
the heater motor i have now doesnt work, im not sure if its the motor of something else in the wiring, is that little resistor setup for the fan speed control prone to failure? or is it likely the factory terminal, the one thats directly in the line of fire from my passenger front tire maybe? anyone experienced this?
post #15 of 85 Old 02-27-2007, 04:51 AM
solitudetree
Your switch could be bad or there's a short somewhere. The blower motor is a metal to metal ground if I remember correctly.
Heater blower motor dustbag Jeep CJ Forum 15 10-17-2009 07:11 AM
Did heater core, and blower motor upgrade, no fan now. Blthomas Jeep CJ Forum 13 02-13-2009 03:00 AM
Blower motor upgrade ? Fuzz21 Jeep CJ Forum 7 09-25-2007 04:58 AM
Heater blower upgrade and question.... dali555 Jeep CJ Forum 4 12-30-2004 08:33 PM
Did blower motor upgrade. WOW! 390fastback Jeep CJ Forum 10 09-29-2004 04:36 PM
