Headlights - JeepForum.com
post #1 of 14 Old 03-20-2012, 09:19 PM Thread Starter
jeepzoob
1983 CJ7
Headlights
Parking lights come on but head lights do not? Any idea?
jeepzoob is offline
post #2 of 14 Old 03-20-2012, 09:25 PM
walkerhoundvm
1981 CJ8
Jiggle the floor switch. May need replacing if that doesn't work. Try a search here, this comes up about once a week, for other ideas
walkerhoundvm is offline
post #3 of 14 Old 03-20-2012, 09:53 PM
Trapshooter
Like walderhoundvm said.....cycle the high beam switch, if the lights come on you may have a bad switch, very common. If the headlights do not function, check the fuses, if the fuse is good, pull a headlight and check for voltage.
Good Luck.......
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #4 of 14 Old 03-20-2012, 10:45 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
have you rewired or replaced your headlight switch? if you have this could be the issue. other than that its most likely the floor switch or the fuses as already stated.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #5 of 14 Old 03-21-2012, 02:51 AM
John Strenk
John Strenk's Avatar
1976 CJ5
No fuse for the headlight, just a circuit breaker in the headlight switch.
John Strenk is offline
post #6 of 14 Old 03-21-2012, 02:58 AM
BagusJeep
1981 CJ7
Get a test light and get down on the floor. Pull that 3 pin plug and test for voltage. If you have then it i sprobably the switch, if not then it is maybe the main switch on the dash.
John Strenk is right, as the fuse box schematic shows the headlights are not run through the fuse box, for safety reasons you do not want a 5c fuse in there waiting to pop at 60mph on a dark night:
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #7 of 14 Old 03-21-2012, 03:06 PM Thread Starter
jeepzoob
1983 CJ7
It was the floor switch
jeepzoob is offline
post #8 of 14 Old 03-21-2012, 04:01 PM
Trapshooter
Glad you found the problem.......
My 401 build:
post #9 of 14 Old 10-02-2012, 11:09 PM
stephens_cj5
1981 CJ5
No headlights
I'm the same issue.
Driving lights, brake lights and dash lights are on. No headlight (low or high).
The test light on the high bean switch and head light connector was negative.
I checked the fuses and they are good.
My hazards and blinkers do not work but I believe that is the switch on the column.
Ideas?
1981 CJ5 ground up restro in progress, finished product will have: 4.2 w/ a 4.0 head conversion, headers, Howell TBI, HEI, D300, AMC 20, D30, 3" lift w/ 33x12.50 BFG. All new hardware, all diffs rebuilt.
stephens_cj5 is offline
post #10 of 14 Old 10-03-2012, 09:40 AM
John Strenk
1976 CJ5
Originally Posted by stephens_cj5 View Post
I'm the same issue.
Ideas?
Were on the high bean switch did you test?
Did you test the wire going to the high bean switch from the head light switch.
Was there power there?
If no power to the High Bean switch then it could be the circuit breaker inside the switch or a poor/loose connection on the head light switch plug.
IF there is power to the high bean switch then it's probably a bad high bean switch.
post #11 of 14 Old 10-03-2012, 11:39 AM
stephens_cj5
1981 CJ5
I removed the high beam switch on the floor from the connector and inserted the check light in each of the three slits on the connector. I had the battery charger connected to the battery terminals on the jeep for power and key turned on.
post #12 of 14 Old 03-05-2013, 07:47 AM
DoubleDown
1983 CJ7
I'm having the same issue, I replaced the switch which helped, but the real problem is the wires going into the switch. They are corroded and need to be replaced. Anyone know the best way ? Should I cut each one and replace the ends or is there a harness I can buy to replace that whole section ?
DoubleDown is offline
post #13 of 14 Old 03-05-2013, 08:00 AM
DoubleDown
1983 CJ7
I think I found the harness, does anyone know where the ends of the wires connect ? And how easy or difficult it is ?
post #14 of 14 Old 03-06-2013, 03:15 AM
John Strenk
1976 CJ5
Well the fun part is the CJ has 4 to 5 wires coming off the switch.
1. Power to switch
2. Low Beams
3. High Beams
4. Hi Beam indicator light (Same terminal as Hi Beam)
5. control off Fog light relay. ( Same terminal as Low Beam)
you can use that but you would have to slice two wire into one coming off the plug.
The only important one is the center one as that has power coming in, the other two can be reversed and not make any difference on operation.
