Headlight upgrade question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Headlight upgrade question
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 08-08-2012, 10:08 AM   #1
VICJ7
Hey all, I know this topic is is beat to death in search, which is how I found these two links.
http://www.quadratec.com/products/97009_110.htm
http://www.streetbeatcustoms.com/ADS...-Relay/532243/
Will I be all set by installing both these? Do I need anything else? Can't tell if switches come with either one. If not, what's the best switch that will not blow.
Thx all.
VICJ7 is offline   Reply With Quote
Unread 08-08-2012, 10:39 AM   #2
CSP
With the relays very little amperage will be going through the switch. That's the whole idea behind relays. You have little voltage drop between the power source and the lights and your switch is exposed to less power going through it.
CSP is offline   Reply With Quote
Unread 08-08-2012, 10:44 AM   #3
VICJ7
great, so I'm good with these two. Thx!
Unread 08-08-2012, 11:01 AM   #4
JrTjK
is that the same harness as http://www.amazon.com/Putco-230004HW...adlight+wiring just $50 more?
JrTjK is offline   Reply With Quote
Unread 08-08-2012, 11:23 AM   #5
VICJ7
seems sketchy imo by reading the reviews.
But who knows....
Unread 08-10-2012, 08:55 AM   #6
Agar426
1974 CJ6
If you don't mind spending a little money, contact either Daniel Stern Lighting, or Susquehanna MotorSports. They will both spend an hour on the phone with you giving you any and all information you need, and they can set you up with a proven "recipe" for upgrading your headlights. I went to Daniel Stern for my '74 CJ and Susquehanna for my TJ. Oddly enough, the harness I got from Stern came from the other, so I think that he contracts out to them to make the harnesses. Anyhow, the experience was quick, educational, and the results speak for themselves (TJ....CJ still being re-assembled). The stuff wasn't cheap, but they both went out of their way to give me the most bang for the buck. For example, for my CJ, I ordered the Cibie reflectors, which are quite a bit more expensive than the Hellla, IPF, etc. That was my choice, not theirs....they gave me plenty of options. The quality of the harness is superb, and their service was also fantastic!
Agar426 is offline   Reply With Quote
