Headlight upgrade - JeepForum.com
post #1 of 9 Old 10-28-2009, 11:47 AM Thread Starter
spoonkilr
Headlight upgrade
Gentleman I have a question...What has everyone found to be the best headlight upgrade? I read that there are now straight plug in replacements for our old dim CJ lights. I am curious what everyone is finding out and upgrading to? Thanks for your imput! Bob
spoonkilr is offline
post #2 of 9 Old 10-28-2009, 11:57 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I have seen everything from the adapters that you can install to allow the use of those Halogen 'capsule' bulbs like modern cars use to DOT approved LED headlight bulbs. Have you removed the old bulbs and installed newer ones? The newer ones are usually Halogen, and mine are nice and bright.
Other things to think of besides dim bulbs - Are the grounds to the bulbs good? Try running dedicated grounds. Also do what many have done and put a relay in to give the bulbs power directly from the battery, using the headlight switch to turn the relay on/off. These 2 things will greatly improve any headlight system. Any other issue may be your charging system getting weak. Low output from your alternator would also cause dim headlights.
Rick
Cutlass327 is offline
post #3 of 9 Old 10-28-2009, 11:58 AM
JeffreyCharles
1976 CJ5
Beyond just replacing bulbs you'll find that installing relays will make a big difference in terms of the amount of power getting to the bulbs (and it's wise to use heavier wiring as well). Here's an account of my experience doing this (to great effect).
Lighting Upgrade - Approach and Auxiliary Fuse Block (Small Craft Net)
Hope this helps.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #4 of 9 Old 10-28-2009, 12:00 PM
Mike Romain
Well, the 'plug in' ones will plug in, but they will fry the breaker in the headlight switch very quickly. You will need to add relays to the circuit so the lights get direct fused power and the switch just triggers it. This will give you sweet white lights.
http://www.jeepforum.com/forum/f8/tr...failed-723399/ Is a good link to the schematics.
Mike
Mike Romain is offline
post #5 of 9 Old 10-28-2009, 12:14 PM
kickingprop
http://www.jeepforum.com/forum/f8/he...t-mods-686559/
Thats's a pretty thorough write-up on various wiring and headlight upgrades. I did this upgrade and have been VERY pleased with the results.
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #6 of 9 Old 10-28-2009, 12:19 PM Thread Starter
spoonkilr
headlights
Thanks for the quick replays...Let me say that the old lights are still in the jeep and working.I guess what I am looking for is a easy and brighter headlight. Will the new halogen bulbs plug in and not fry any of the old circuits. Do i have put relays in to change to new halogen bulbs?? So for the newby questions? thanks in advance. Bob
post #7 of 9 Old 10-28-2009, 12:52 PM
Mike Romain
Yes, you must use relays for halogen lights or you will fry the switch, usually sooner than later.
Even putting the relays on your existing lights will make an amazing difference, they will turn white.
Mike
post #8 of 9 Old 10-28-2009, 12:58 PM
kickingprop
x2
Relays wired in made the single greatest difference in getting good power to the headlights.
Also, clean up and make sure you have a good ground for the headlights. This will also be a quick headlight quality killer
1985 CJ7 Project
post #9 of 9 Old 10-28-2009, 09:44 PM
mcjeeper74
1972 C104
I just did the relay upgrade this week and I run Sylvanya XTRAvision lights and this was a big improvement took about 2 hours to make the harness and install. I recommend the relays first it will make the biggest difference in output.
mcjeeper74 is offline
Headlight/Headlight Switch Fix - Preventive IdahoJeeper Jeep CJ Forum 9 08-01-2009 04:08 PM
pics of headlight upgrade outcome twoleos617 Jeep CJ Forum 0 07-02-2009 09:29 PM
Question about JeepHammer's headlight wiring upgrade chet44 Jeep CJ Forum 6 06-13-2009 04:44 PM
258 EFI upgrade & YJ spring upgrade jeepin'bo Jeep CJ Forum 2 04-08-2005 06:02 AM
H4 Headlight Upgrade on a CJ sbestmann Jeep CJ Forum 25 02-05-2004 05:14 PM
