Headlight upgrade - Page 2 - JeepForum.com
post #16 of 27 Old 02-03-2013, 11:29 AM
MoC
Something like this that seals them up better from the elements. These are from a YJ harness, the wires are just to small.
MoC is offline
post #17 of 27 Old 02-03-2013, 11:33 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
Ah. Nope, I just use em bare with some of the "waterproof" connectors, no problems yet
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #18 of 27 Old 02-03-2013, 02:33 PM
aggiejon
1979 CJ7
Originally Posted by mvigo
or, you can really get an improvement and upgrade your headlight wiring harness using relays...
these threads me helped immensely:
http://www.jeepforum.com/forum/f20/m...inside-510221/
In this thread JeepHammer goes into detail on what to do:
http://www.jeepforum.com/forum/f8/he...t-mods-686559/
I bought my parts from Daniel Stern, his website is helpful as well:
http://www.danielsternlighting.com/
once you complete this easy project, any head lamp you throw on your Jeep is a vast improvement because your new wiring harness can supply the adequate juice to the lights instead of starving them with the stock OEM wiring. A very worthwhile project...
X2. I have delta halogens plus relay upgrade. Boost your supply wire gauge and light up the night. For the $20 this mod costs, why wouldn't you?
aggiejon is offline
post #19 of 27 Old 02-03-2013, 06:43 PM Thread Starter
Jsadamson1
Awesome guys, thanks for all the help. I think I will do the wire upgrade and put in the halogens like a few people have done. Seems to be the best and most economical upgrade. I will post with my results and if I found out any new info while doing so.
Jason
Follow my Jeep Builds!
jeepbuilds.blogspot.com
Jsadamson1 is offline
post #20 of 27 Old 02-03-2013, 07:21 PM
RobsCrawlin7
no balls
Jason
remember, you can always try the wiring and if it isn't enough get the lights...the plugs are the same.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #21 of 27 Old 02-04-2013, 06:29 AM
MoC
Does anyone know if the smaller self reseting fuses Hammer recommends (one for easy normal beam and one for both high's) are the size of a traditional ATX fuse and will fit in a ATX fuse box like this one?
http://www.extremeterrain.com/painle...673&adtype=pla
MoC is offline
post #22 of 27 Old 02-18-2013, 05:22 PM Thread Starter
Jsadamson1
So I did the upgrade with the hella lights, super white H4 bulbs and the relay pack. WHAT A DIFFERENCE! I am stoked at the outcome and was worth every penny to be able to see. I did however hook up the wrong signal wire up to my relays so my brights are backwards, not a big deal and I am too lazy to fix at this point!
Thanks all for your help!
post #23 of 27 Old 02-18-2013, 07:05 PM
auskier
1983 CJ7
They are kinda pricy, but I totally agree with the trucklite upgrade. No need to worry about wiring/relay upgrades. Low beam is 1.8 amps, high beam is 3.6 amps. NO COMPARISON to anything I have used, and they look good too. First photo is of the list, next photo is of the street.
Brian
auskier is offline
post #24 of 27 Old 02-18-2013, 07:09 PM
auskier
1983 CJ7
Field of view
auskier is offline
post #25 of 27 Old 02-18-2013, 07:40 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Brian
Yes! I recommend taking your parking lights out and painting the reflectors (the round silver backing) black. It doesn't diminish the light output at all.
Mail crawling.
MisfitSeven is offline
post #26 of 27 Old 02-28-2013, 02:10 PM
jakwi
I was looking for the same thing a waterproof box and relays to fit. So far all I have found is this waterproof box
http://www.amazon.com/HELLA-H8498800...xgy_auto_img_y
and the relay's to go with it
http://www.amazon.com/HELLA-H4177300...spst+relay+12v
In the end they are too much for my budget, or at least I'd rather spend the money on other things.
jakwi is offline
post #27 of 27 Old 02-28-2013, 02:25 PM
jakwi
Here is a better option that uses common relays and fuses.
http://www.peerlesselectronics.com/s...2d0%252d4.html
jakwi is offline
